tuantrinhdp Posted April 9, 2023 Posted April 9, 2023 Hi everyone. I need: - display text ( no Z) on 3D polyline ( include: donut yellow, choose text height) - convert 3D polyline to 2D polyline Can you help me write lisp with my request, please? TEST.dwgFetching info... Quote
BIGAL Posted April 9, 2023 Posted April 9, 2023 (edited) Try Label 3dpolys By Alan H April 2023 (defun c:wow ( / obj co-ords pt lst2 lwpoly) (defun LWPoly (plst lay col cls) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 8 lay) (cons 62 col) (cons 90 (length plst)) (cons 70 cls)) (mapcar (function (lambda (p) (cons 10 p))) plst) ) ) ) (Prompt "select 3d polylines ") (setq ss (ssget '((0 . "POLYLINE")))) (if ss (repeat (setq k (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq k (1- k))))) (setq co-ords (vlax-get obj 'coordinates)) (setq co-ordsxy '()) (setq I 0) (repeat (/ (length co-ords) 3) (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 3)) ) (setq lst2 '()) (foreach pt co-ordsxy (setq pt (list (car pt)(cadr pt) (caddr pt))) (command "text" "C" pt 1.5 0.0 (rtos (caddr pt) 2 2)) (command "-insert" "Donut" "s" 1 (list (car pt)(cadr pt)) 0.0) (setq lst2 (cons (list (car pt)(cadr pt)) lst2)) ) (LWPoly lst2 (vla-get-layer obj) (vla-get-color obj) 0) (vla-delete obj) ) (alert "No 3dpoly's chosen ") ) (princ) ) (c:wow) this. Edited April 16, 2023 by BIGAL 1 Quote
tuantrinhdp Posted April 9, 2023 Author Posted April 9, 2023 On 4/9/2023 at 7:14 AM, BIGAL said: Try (defun co-ords2xy (xyz / ) (setq co-ordsxy '()) (if (= xyz 2) (progn (setq I 0) (repeat (/ (length co-ords) 2) (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 2)) ) ) ) (if (= xyz 3) (progn (setq I 0) (repeat (/ (length co-ords) 3) (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 3)) ) ) ) ) (defun c:wow ( / ) (setq obj (vlax-ename->vla-object (car (entsel "Pick obj")))) (setq co-ords (vlax-get obj 'coordinates)) (cond (( = (vla-get-objectname obj) "AcDb2dPolyline")(co-ords2xy 2)) (( = (vla-get-objectname obj) "AcDb3dPolyline")(co-ords2xy 3)) ) (princ co-ordsxy) (foreach pt co-ordsxy (setq pt (list (car pt)(cadr pt) (caddr pt))) (command "text" "C" pt 1.5 0.0 (rtos (caddr pt) 2 2)) ) (princ) ) (c:wow) this. Expand Successful, can you help me to add block reference ( donut color yellow, - My attachment has a yellow block ref.) under the text? With additional conditions to choose text size ? Thank you so much. Quote
BIGAL Posted April 9, 2023 Posted April 9, 2023 (edited) Added donut (foreach pt co-ordsxy (setq pt (list (car pt)(cadr pt) (caddr pt))) (command "text" "C" pt 1.5 0.0 (rtos (caddr pt) 2 2)) (command "-insert" "Donut" "s" 1 (list (car pt)(cadr pt)) 0.0) ) Edited April 10, 2023 by BIGAL Quote
mhupp Posted April 10, 2023 Posted April 10, 2023 Quote Expand On 4/9/2023 at 2:10 AM, tuantrinhdp said: - convert 3D polyline to 2D polyline Expand Use the flatten command 1 Quote
tuantrinhdp Posted April 10, 2023 Author Posted April 10, 2023 On 4/9/2023 at 11:45 PM, BIGAL said: Added donut (foreach pt co-ordsxy (setq pt (list (car pt)(cadr pt) (caddr pt))) (command "text" "C" pt 1.5 0.0 (rtos (caddr pt) 2 2)) (command "-insert" "Donut" "s" 1 pt 0.0) ) Expand Thank you so much. Quote
BIGAL Posted April 16, 2023 Posted April 16, 2023 I have updated the code in post 2to include more functionality, as requested. 1 Quote
ArbaDan75 Posted April 28, 2023 Posted April 28, 2023 (edited) On 4/9/2023 at 7:14 AM, BIGAL said: Try Label 3dpolys By Alan H April 2023 (defun c:wow ( / obj co-ords pt lst2 lwpoly) (defun LWPoly (plst lay col cls) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 8 lay) (cons 62 col) (cons 90 (length plst)) (cons 70 cls)) (mapcar (function (lambda (p) (cons 10 p))) plst) ) ) ) (Prompt "select 3d polylines ") (setq ss (ssget '((0 . "POLYLINE")))) (if ss (repeat (setq k (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq k (1- k))))) (setq co-ords (vlax-get obj 'coordinates)) (setq co-ordsxy '()) (setq I 0) (repeat (/ (length co-ords) 3) (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 3)) ) (setq lst2 '()) (foreach pt co-ordsxy (setq pt (list (car pt)(cadr pt) (caddr pt))) (command "text" "C" pt 1.5 0.0 (rtos (caddr pt) 2 2)) (command "-insert" "Donut" "s" 1 (list (car pt)(cadr pt)) 0.0) (setq lst2 (cons (list (car pt)(cadr pt)) lst2)) ) (LWPoly lst2 (vla-get-layer obj) (vla-get-color obj) 0) (vla-delete obj) ) (alert "No 3dpoly's chosen ") ) (princ) ) (c:wow) this. Expand Edited April 28, 2023 by ArbaDan75 Quote
ArbaDan75 Posted April 28, 2023 Posted April 28, 2023 (edited) Tahnks! Very nice! You could substitute "(command "-insert" "Donut" "s" 1 (list (car pt)(cadr pt)) 0.0)" with "(command "point" pt)". Edited April 28, 2023 by ArbaDan75 Quote
