My lines are not being drawn with zero Z value
Hi, I'm not sure what happened but my lines now keep being drawn not flat. I keep trying to flatten the drawings then the drawings don't become flat, certain lines become separated and slanted even more. I've changed OSNAPZ to 1, as well. Would really appreciate how to fix this issue as I'm not able to progress with my work due to this. Thank you.
2 things
UCS W you may have set a UCS that is on a slope compared to world. User co-ordinate system.
Elevation may be set to a Z value reset to zero.
18 hours ago, BIGAL said:
2 things
hi, okay thank you, will try these out!
