ILoveMadoka Posted April 7, 2023 Share Posted April 7, 2023 If an object has a lineweight assigned, assoc code 370 has a value. If it's set to ByLayer 370 does not appear. Lineweight = .35 * List in AutoLISP format *((-1 . <Entity name: 25cbc28c8a0>) (0 . LINE) (330 . <Entity name: 25c196249b0>) (5 . 951A) (100 . AcDbEntity) (67 . 1) (410 . 1) (8 . 0) (370 . 35) (100 . AcDbLine) (10 0.0 0.0 0.0) (11 -2.92396 -1.74585 0.0) (210 0.0 0.0 1.0)) Variable name is ENT (370 . 35) The same line, Lineweight = Bylayer * List in AutoLISP format *((-1 . <Entity name: 25cbc28c8a0>) (0 . LINE) (330 . <Entity name: 25c196249b0>) (5 . 951A) (100 . AcDbEntity) (67 . 1) (410 . 1) (8 . 0) (100 . AcDbLine) (10 0.0 0.0 0.0) (11 -2.92396 -1.74585 0.0) (210 0.0 0.0 1.0)) Variable name is ENT 370 is missing. Is it NIL? How can I select all objects where 370 has a value? (setq LW (ssget "_X" '((370 . ??Has some value??)))) ;;;???? Quote Link to comment Share on other sites More sharing options...
mhupp Posted April 7, 2023 Share Posted April 7, 2023 (edited) (setq LW (ssget "_X" '((370 . *)))) -Edit That wouldn't work because bylayer is shown as -1 byblock as -2 but doesn't show up with entget. Using Relational Operators with ssget (setq LW (ssget "_X" '((-4 . ">") (370 . 0)))) Edited April 7, 2023 by mhupp 1 Quote Link to comment Share on other sites More sharing options...
devitg Posted April 7, 2023 Share Posted April 7, 2023 13 minutes ago, mhupp said: (ssget '((0 . "LWPOLYLINE") (-4 . ">") (370 . 0))) @mhupp Work as need , thanks Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted April 7, 2023 Author Share Posted April 7, 2023 For my situation this is the winner.. (setq LW2 (ssget "_X" '((-4 . ">") (370 . 0)))) Thank you so very much!! Quote Link to comment Share on other sites More sharing options...
devitg Posted April 7, 2023 Share Posted April 7, 2023 1 hour ago, mhupp said: That wouldn't work because bylayer is shown as -1 byblock as -2 but doesn't show up with entget. @mhupp please clear me , Where it come from? LISP DATA INSPECTOR 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted April 7, 2023 Share Posted April 7, 2023 @devitg its part of blade. Quote BricsCAD LISP Advanced Development Environment (BLADE) to interactively edit and debug LISP applications. It opens in an external application window, allowing it to remain open while you work on your drawings in BricsCAD. You can move and resize it with standard application window controls. 1 Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 7, 2023 Share Posted April 7, 2023 LineWeights : Default & ByBlock have minus values so they won't be selected with your proposal bigger than zero. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 7, 2023 Share Posted April 7, 2023 In addition to what @mhupp suggested, here is a variation to work with Default & ByBlock as well. (setq LW (ssget "_X" '((-4 . "<OR") (370 . -2) (370 . -3) (-4 . "<AND")(-4 . ">") (370 . 0) (-4 . "AND>") (-4 . "OR>")))) 1 Quote Link to comment Share on other sites More sharing options...
