JonesyCJones Posted April 6, 2023 Posted April 6, 2023 Does anyone know how, or have a .ctb pen setting, to have True Colors show as black? We are getting arch backgrounds from the architect that are using True Colors (three number colors), and we haven't found a way to address these and assign them to print black. Quote
BIGAL Posted April 7, 2023 Posted April 7, 2023 (edited) Post a dwg with a couple of lines etc and the ctb. May be a way to edit the ctb. The other way is to edit the color of the objects. Look for any RGB colors and set to black. Edited April 7, 2023 by BIGAL Quote
CyberAngel Posted April 7, 2023 Posted April 7, 2023 The quick and dirty way to change the color table is to switch from colors to styles (the CONVERTPSTYLES command). The potential downside here is that everything changes, not just backgrounds. In theory, I suppose you could switch back to colors, and the offending colors would be reset; that's what the documentation seems to say. Quote
