thekiki Posted April 6, 2023 Share Posted April 6, 2023 Hi all, I'm looking for a lisp that when i click on the polyline, i can select all the polylines 1/ having the same thickness, never mind the color or linetype (solution n°1) 2/ having the same thickness and color, never mind the linetype (solution n°2). Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Steven P Posted April 6, 2023 Share Posted April 6, 2023 I've not been concentrating on this forum for a couple of weeks, the boss wants me to work (which is odd), so not sure how you are with making up a LISP, if I give you some ideas will that help? (the boss still wants work done today, I need to have a word with the boss.....) You can select a polyline with (entsel) or (ssget), ssget might be better here using the reference document from Lee Mac as a guide - filter the selection set for single object selection and for polyline, and then after (entget (ssname -selectionSet- 0) ) to get the entity selected. From there you can get the thickness using (assoc ....) number 39 And colour using (assoc... ) again, with code 62 Finally do a new selection set for all items filtering it for (0 . "*POLYLINE")(39 . THICKENSS)(62 . COLOUR) - again using whatever reference online on how to make up the selection set. THICKNESS and COLOUR are what you found from the assoc lines Hope that helps a bit. Last question, I am assuming you mean thickness and not line width which is assoc code 40 The internet can help you put all of this together - but ask where you get stuck and even showing off when you get it to work Quote Link to comment Share on other sites More sharing options...
Tsuky Posted April 6, 2023 Share Posted April 6, 2023 Why not familiarize yourself with the FILTER command. It would be simpler than to build a lisp, in addition once the use acquired, FILTER will allow you to make multiple filters which could be useful to you thereafter to build your selections quickly. Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted April 6, 2023 Share Posted April 6, 2023 Here's the basis. The only thing is: it doesn't work for ByLayer. Command SPST expects the source object to have a line thickness. Command SPSTC expects the source object to have a line thickness and color. ;; 1/ having the same thickness, never mind the color or linetype (defun c:spst ( / source thickness ss i pickset) ;; user selects source (setq source (car (entsel "\nSelect Source object: "))) ;; read line thickness (setq thickness (cdr (assoc 370 (entget source)))) ;; line thickness ;; select all ploylines with that thinkness (setq ss (ssget "_X" (list (cons 0 "*POLYLINE") (cons 370 thickness)))) ;; now grip these objects (setq pickset (ssadd)) (setq i 0) (repeat (sslength ss) (ssadd (ssname ss i) pickset) (setq i (+ i 1)) ) ;; this grips the objects (sssetfirst nil pickset) ) ;; 2/ having the same thickness and color, never mind the linetype (solution n°2). (defun c:spstc ( / source thickness ss i pickset) (setq source (car (entsel "\nSelect Source object: "))) (setq thickness (cdr (assoc 370 (entget source)))) ;; line thickness (setq color (cdr (assoc 62 (entget source)))) ;; color (setq ss (ssget "_X" (list (cons 0 "*POLYLINE") (cons 370 thickness) (cons 62 color)))) (setq pickset (ssadd)) (setq i 0) (repeat (sslength ss) (ssadd (ssname ss i) pickset) (setq i (+ i 1)) ) (sssetfirst nil pickset) ) Quote Link to comment Share on other sites More sharing options...
thekiki Posted April 6, 2023 Author Share Posted April 6, 2023 Thanks Emmanuel, but it doesn't work (on the screen we can see: "Select Source object: ; erreur: valeur de liste SSGET incorrecte") Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted April 6, 2023 Share Posted April 6, 2023 Oh, you got a French Autocad. Yeah, that complicates things. Quote Link to comment Share on other sites More sharing options...
thekiki Posted April 6, 2023 Author Share Posted April 6, 2023 Ah!? You think that french version have a little problem! Quote Link to comment Share on other sites More sharing options...
Tsuky Posted April 6, 2023 Share Posted April 6, 2023 Otherwise if you really need a lisp, I have this: Run DYN_FILTER, move your cursor over a source entity; watch your status bar where the DXF codes of the entity should appear. If these seem suitable to you, validate with a right-click. From then on the command (ssget '_X') will appear on the command line with the corresponding options (only the most common DXF codes are used) Here again you have the possibility of removing certain DXF codes to make the selection more general. However, you must know the most common DXF codes to use it effectively... (defun data2string (l_dxf / l_dxf lst_pair grp_el typ_el ch1 ch2 ch) (setq ch "") (while l_dxf (setq lst_pair (car l_dxf)) (setq grp_el (car lst_pair) typ_el (cdr lst_pair)) (cond ((eq (type grp_el) 'INT) (setq ch1 (itoa grp_el)) ) ((eq (type grp_el) 'REAL) (setq ch1 (rtos grp_el 2 4)) ) ((eq (type grp_el) 'STR) (setq ch1 (strcat "\"" grp_el "\"")) ) (T (setq ch1 "") ) ) (cond ((eq (type typ_el) 'INT) (setq ch2 (itoa typ_el)) ) ((eq (type typ_el) 'REAL) (setq ch2 (rtos typ_el 2 4)) ) ((eq (type typ_el) 'STR) (setq ch2 (strcat "\"" typ_el "\"")) ) ((eq (type typ_el) 'LIST) (setq ch2 (strcat (rtos (car typ_el) 2 4) " " (rtos (cadr typ_el) 2 4) (if (caddr typ_el) (strcat " " (rtos (caddr typ_el) 2 4)) ""))) ) (T (setq ch2 "") ) ) (if (eq (type typ_el) 'LIST) (setq ch (strcat ch "(" ch1 " " ch2 ") ")) (setq ch (strcat ch "(" ch1 " . " ch2 ") ")) ) (setq l_dxf (cdr l_dxf) ch1 "" ch2 "") ) (strcat "(" ch ")") ) (defun c:dyn_filter ( / sv_shmnu oldim key pt_sel l_dxfcod m_filt ent dxf_ent typ_ent msg ss) (setq sv_shmnu (getvar "SHORTCUTMENU") oldim (getvar "dimzin") ) (setvar "dimzin" 0) (setvar "SHORTCUTMENU" 11) (while (and (setq key (grread T 4 0)) (not (member key '((2 13) (2 32)))) (/= (car key) 25)) (setq l_dxfcod nil m_filt nil pt_sel (osnap (list (caadr key) (cadadr key)) "_near") ) (if pt_sel (progn (setq ss (ssget "_C" pt_sel pt_sel)) (if ss (setq ent (ssname ss 0))) ) (setq ent (car (nentselp (list (caadr key) (cadadr key))))) ) (cond (ent (setq dxf_ent (entget ent)) (setq l_dxfcod (append '(38 39 48 370 62 6 8 67 0) l_dxfcod)) (if (member (cdr (assoc 0 dxf_ent)) '("HATCH" "INSERT" "MLINE" "SHAPE")) (if (assoc 2 dxf_ent) (setq l_dxfcod (cons 2 l_dxfcod))) ) (foreach n l_dxfcod (if (assoc n dxf_ent) (setq m_filt (cons (assoc n dxf_ent) m_filt)))) (grtext -2 (data2string m_filt)) ) (T (grtext -2 "")) ) ) (cond (dxf_ent (setq typ_ent (cdr (assoc 0 dxf_ent)) m_filt nil) (cond ((eq typ_ent "LWPOLYLINE") (setq l_dxfcod (cons 43 l_dxfcod)) ) ((or (eq typ_ent "POLYLINE") (eq typ_ent "MLINE") (eq typ_ent "SPLINE")) (setq l_dxfcod (cons 70 l_dxfcod)) ) ((or (eq typ_ent "DIMENSION") (eq typ_ent "LEADER")) (setq l_dxfcod (cons 3 l_dxfcod)) (setq l_dxfcod (cons 70 l_dxfcod)) ) ((or (eq typ_ent "ARC") (eq typ_ent "CIRCLE") (eq typ_ent "ELLIPSE")) (setq l_dxfcod (cons 40 l_dxfcod)) ) ((or (eq typ_ent "TEXT") (eq typ_ent "MTEXT") (eq typ_ent "ATTDEF")) (setq l_dxfcod (cons 7 l_dxfcod)) (setq l_dxfcod (cons 40 l_dxfcod)) ) ) (foreach n l_dxfcod (if (assoc n dxf_ent) (setq m_filt (cons (assoc n dxf_ent) m_filt)))) (princ (strcat "\n(ssget \"" "_X" "\" " (data2string m_filt) ")")) (setq msg "") (initget (foreach n m_filt (setq msg (strcat (itoa (car n)) " " msg)))) (setq msg "") (setq msg (strcat "\nDXF code to delete? [" (foreach n m_filt (setq msg (strcat (itoa (car n)) "/" msg))) "]")) (while (setq what (getkword msg)) (setq m_filt (vl-remove (assoc (atoi what) m_filt) m_filt)) (princ (strcat "\n(ssget \"" "_X" "\"" (data2string m_filt) ")")) (setq msg "") (initget (foreach n m_filt (setq msg (strcat (itoa (car n)) " " msg)))) (setq msg "") (setq msg (strcat "\nDXF code to delete? [" (foreach n m_filt (setq msg (strcat (itoa (car n)) "/" msg))) "]")) ) (if (zerop (getvar "PICKFIRST")) (setvar "PICKFIRST" 1)) (sssetfirst nil nil) (setq ss (ssget "_X" m_filt)) (princ (strcat "\n" (itoa (sslength ss)) " selected similar objects.")) (sssetfirst nil ss) ) (T (princ "\nNo selection")) ) (setvar "SHORTCUTMENU" sv_shmnu) (setvar "dimzin" oldim) (prin1) ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted April 6, 2023 Share Posted April 6, 2023 1 hour ago, Emmanuel Delay said: Oh, you got a French Autocad. Yeah, that complicates things. would this be the fix? (setq ss (ssget "_X" '((0 . "*POLYLINE") (370 . thickness)))) Thinking language variation and taking out English words in the commands? Quote Link to comment Share on other sites More sharing options...
devitg Posted April 6, 2023 Share Posted April 6, 2023 8 minutes ago, Steven P said: "_X" Underscore prefix allow not english ACAD , to be as english . 1 Quote Link to comment Share on other sites More sharing options...
Tsuky Posted April 6, 2023 Share Posted April 6, 2023 @Emmanuel Delay Your code is good even in French It would only be necessary to agree on the term thickness (Height of the polyline: DXF 39 or Lineweight of the polyline: DXF 370) Because indeed if the polyline entity has no Lineweight then your code fails (bad list for ssget) If the polyline has Lineweight then it works Quote Link to comment Share on other sites More sharing options...
thekiki Posted April 6, 2023 Author Share Posted April 6, 2023 DWG attached to be more explicit TEST.dwg Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted April 6, 2023 Share Posted April 6, 2023 Ah, I get it. Your line thinkness is not line thickness, it's global width of the polyline. I'll see what I can do tomorrow (unless someone is faster) Quote Link to comment Share on other sites More sharing options...
thekiki Posted April 6, 2023 Author Share Posted April 6, 2023 Exactly! Quote Link to comment Share on other sites More sharing options...
Tsuky Posted April 6, 2023 Share Posted April 6, 2023 @thekiki So simply replace in Emmanuel's code 370 by 43 Quote Link to comment Share on other sites More sharing options...
devitg Posted April 6, 2023 Share Posted April 6, 2023 33 minutes ago, Emmanuel Delay said: I'll see what I can do tomorrow (unless someone is faster) On @Emmanuel Delay permit ;; 1/ having the same thickness, never mind the color or linetype (defun c:spst-43 ( / source thickness ss i pickset) ;; user selects source (setq source (car (entsel "\nSelect Source object: "))) ;; read line thickness (setq thickness (cdr (assoc 43 (entget source)))) ;; line thickness ;; select all ploylines with that thinkness (setq ss (ssget "_X" (list (cons 0 "*POLYLINE") (cons 43 thickness)))) ;; now grip these objects (setq pickset (ssadd)) (setq i 0) (repeat (sslength ss) (ssadd (ssname ss i) pickset) (setq i (+ i 1)) ) ;; this grips the objects (sssetfirst nil pickset) ) ;; 2/ having the same thickness and color, never mind the linetype (solution n°2). (defun c:spstc-43-62 ( / source thickness ss i pickset) (setq source (car (entsel "\nSelect Source object: "))) (setq thickness (cdr (assoc 43 (entget source)))) ;; line thickness (setq color (cdr (assoc 62 (entget source)))) ;; color (setq ss (ssget "_X" (list (cons 0 "*POLYLINE") (cons 43 thickness) (cons 62 color)))) (setq pickset (ssadd)) (setq i 0) (repeat (sslength ss) (ssadd (ssname ss i) pickset) (setq i (+ i 1)) ) (sssetfirst nil pickset) ) 1 Quote Link to comment Share on other sites More sharing options...
devitg Posted April 6, 2023 Share Posted April 6, 2023 47 minutes ago, thekiki said: DWG attached to be more explicit TEST.dwg 83.89 kB · 3 downloads The DWG should be at your first post , a DWG worth 1000000000 words. 1 Quote Link to comment Share on other sites More sharing options...
thekiki Posted April 6, 2023 Author Share Posted April 6, 2023 That's perfect! Many thanks! 1 Quote Link to comment Share on other sites More sharing options...
devitg Posted April 6, 2023 Share Posted April 6, 2023 2 hours ago, thekiki said: That's perfect! Many thanks! @thekiki Never forget to upload the sample.dwg when asking for help. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 7, 2023 Share Posted April 7, 2023 Thickness v's width Quote Link to comment Share on other sites More sharing options...
