Hi,
a found some offset lisp, but is it possible to
offset e.g. the long side with a distance and the short side with an another distance.
Offset: Layer as current and exlode the of line.
Thanks for help.
Is the rectangle drawn as a polyline? in which case yes you can:
- Ask user for offset values
- Select rectangle
- Use Entity details to get the corner points (entget and assoc value 10)
- calculation rotation of the rectangle (or angle)
- calculate long sides (distance)
- use polar calculation to work out new points
- entmod the original rectangle
Have a go and see how you do with that - am sure you can do some of this yourself, asking advice where you need it
This is get the co-ordinates.
(setq plent (entsel "\nPick rectang"))
(if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
(princ co-ord)
  • Like 2
