Sin Tax - (ssget) issue
ILoveMadoka
I'm wanting to select all objects where the linetype is not Continuous, Center or Dashed.
I want to pass on objects without a linetype assignment.
This is what I have but my syntax in messed up
(defun c:FLT ()
  (setq LT1 (ssget "_X" '((6 . "<NOT") ("DASHED" "CENTER" "CONTINUOUS")  ))
   all (ssname LT1 0)
Am I even close??
Edited by ILoveMadoka
This is a great reference:
http://lee-mac.com/ssget.html
Looking through that and the 'not' example
(ssget '((0 . "LINE") (-4 . "<NOT") (62 . 256) (-4 . "NOT>")))
and I think you'll need an OR in the NOT to create the list of exclusions:
(setq ss (ssget "_X" '((0 . "LINE") (-4 . "<NOT") (-4 . "<OR")(6 . "DASHED")(6 . "CENTER")(6 . "CONTINUOUS")(-4 . "OR>") (-4 . "NOT>"))))
EDIT
Should be:
(setq ss (ssget "_X" '((-4 . "<NOT") (-4 . "<OR")(6 . "DASHED")(6 . "CENTER")(6 . "CONTINUOUS")(-4 . "OR>") (-4 . "NOT>"))))
(see below)
Edited by Steven P
What if it's not a line?
are you forced to do something like this?
(0 . "LINE,ARC,CIRCLE,LWPOLYLINE,SPLINE")
Does that cover ALL object types?
these two lines both worked for LINES:
(setq ss01 (ssget "_X" '((0 . "LINE") (-4 . "<NOT") (-4 . "<OR")(6 . "DASHED")(6 . "CENTER")(6 . "CONTINUOUS")(-4 . "OR>") (-4 . "NOT>"))))
(setq ss03 (ssget "_X" '((0 . "LINE") (6 . "~DASHED") (6 . "~CENTER") (6 . "~CONTINUOUS"))))
the other did not (for me)
So this is where I am and it is still only working for lines and polylines
(not splines, lwpolylines, arcs or circles)
(defun c:FLT ()
(setq ssx (ssget "_X" '((0 . "LINE,ARC,CIRCLE,LWPOLYLINE,SPLINE") (6 . "~DASHED") (6 . "~CENTER") (6 . "~CONTINUOUS"))))
Perhaps remove the entity filter ( 0 ).
(setq ss (ssget "_X" '((6 . "~DASHED") (6 . "~CENTER") (6 . "~CONTINUOUS"))))
This works with one issue for me.
It's selecting text/mtext (linetype display in properties is BYLAYER)
(defun c:FLT ()
(setq dx2 (ssget "_X" '((6 . "~DASHED") (6 . "~CENTER") (6 . "~CONTINUOUS"))))
If I can remove the text from the ss I'm golden.
Sorry to be difficult (thank you all for the input!!)
For closure..
(defun c:FLT3 ()
(setq dx2 (ssget "_X" '((0 . "ARC,SPLINE,CIRCLE,HATCH,LINE,LWPOLYLINE,POINT,POLYLINE,SOLID,ELLIPSE,TRACE")
Again, thank you all!
ps: ronjonp - that worked too!
2 minutes ago, ILoveMadoka said:
For closure..
(defun c:FLT3 ()
That won't filter out Linetype BYLAYER items. You might as well use @Tharwat example.. and include "BYLAYER" in the list.
Edited by ronjonp
I think I should go back up and take out 'line' from my answer above - causing some confusion for me just copy and pasting without thinking
(defun c:FLT ()
This one, put (0 . "*text") in your list of 'NOT's, * being a wildcard (so gets text, mtext and rtext)
(defun c:FLT ()
(setq dx2 (ssget "_X" '((0. "~*TEXT") (6 . "~DASHED") (6 . "~CENTER") (6 . "~CONTINUOUS"))))
Edited by Steven P
