kaplan46 Posted April 2, 2023 Posted April 2, 2023 (edited) autolisp output is single line. I want to write a list article, I couldn't, can you help me? Thank you ; (setq output-str (strcat dn-eşdeğeri " - " (rtos input-val) " W\n" (strcat " " (rtos Hızı 2 2) " m/s, " (rtos basınç kaybı)) 2 2) " Pa/m"))) (setq pt (getpoint "\nMetin için ekleme noktasını seçin: ")) (setq text (entmakex (list '(0 . "TEXT") (eksileri 10 pt) (eksileri 40 12) (eksileri 1 çıktı-str)))) (setq pt2 (getpoint pt "\nMetin için dönüş noktasını seçin: ")) ("_.döndür" metin nokta2 "" kesin (açı nokta nokta2) "") (prens) ) Edited April 3, 2023 by SLW210 Added Code Tags!! Quote
mhupp Posted April 2, 2023 Posted April 2, 2023 Going to need a little more info. Biraz daha fazla bilgiye ihtiyaç olacak. Quote
kaplan46 Posted April 3, 2023 Author Posted April 3, 2023 Sonuç : output : DN50-5000 W 0,66 m/s 180 pa/m desired output : DN50-5000 W 0,66 m/s 180 pa/m Quote
devitg Posted April 3, 2023 Posted April 3, 2023 4 hours ago, kaplan46 said: Sonuç : output : DN50-5000 W 0,66 m/s 180 pa/m desired output : DN50-5000 W 0,66 m/s 180 pa/m @kaplan46 Please upload your sample.dwg where to apply the lisp , with BEFORE and AFTER Quote
BIGAL Posted April 4, 2023 Posted April 4, 2023 (alert "desired output :\nDN50-5000 W\n0,66 m/s\n180 pa/m") 1 Quote
devitg Posted April 4, 2023 Posted April 4, 2023 5 hours ago, BIGAL said: (alert "desired output :\nDN50-5000 W\n0,66 m/s\n180 pa/m") @BIGAL This text , will not be Stacked (setq texto "\nDN50-5000 W\n0,66 m/s\n180 pa/m") (setq pto (getpoint)) (setq stack-texto (vla-AddText model texto (vlax-3d-point pto) 25 )) Please clear us. Quote
kaplan46 Posted April 4, 2023 Author Posted April 4, 2023 resolved ; Sonucu bir yazı olarak çizin (setq output-str1 (strcat dn-equivalent " - " (strcat (strcat (substr (rtos input-val 2 0) 1 (- (strlen (rtos input-val 2 0)) 3)) ".") (substr (rtos input-val 2 0) (- (strlen (rtos input-val 2 0)) 2))) " W") output-str2 (strcat "" (rtos velocity 2 2) " m/s, " (rtos pressure-loss 2 0) " Pa/m")) ; Kullanıcıya sonucu yerleştirmesi için işaretçi değişkeni oluşturun (setq pt (getpoint "\nMetin için ekleme noktası seçin: ")) (setq pt1 (polar pt (* pi 1.5) 18.0)) ; Yazıyı belirlenen noktaya yerleştirin ve seçin (setq text (entmakex (list '(0 . "TEXT") (cons 10 pt) (cons 40 12) (cons 1 output-str1)))) (setq text2 (entmakex (list '(0 . "TEXT") (cons 10 pt1) (cons 40 12) (cons 1 output-str2)))) ; Kullanıcıya yazıyı döndürmesi için işaretçi değişkeni oluşturun (setq pt2 (getpoint pt "\nMetin için döndürme noktası seçin: ")) ; Yazıyı belirlenen açıda döndürün (command "_.rotate" text text2 "" pt (angtos (angle pt pt2))) ; Sonucu kaydetmek için işleme bekleyin (princ) ) Quote
