Hello.
I'm experiencing a strange situation with break command. I want to cut a line at a specific place using "nearest" snap.
I use the following commands:
Quote
break
<select a line>
f
<pick a point on the line using "nearest" snap>
This works perfectly, a line splits into two at the selected point.
However, when I attempt use of
(command "break" pause "f" pause "@")
it removes chunk of the line...what am I doing wrong?
P.S.
This worked fine in AutoCAD 2002
[EDIT]
By adding nea before submitting second point seems to fix the issue.
But I still would like to know why there are different results when commands entered manually vs using (command) function
Command: break
Select object:
Specify second break point or [First point]: f
Specify first break point: _nea to
Specify second break point: @
Command: (command "break" pause "f" pause "nea" "@")
break Select object:
Specify second break point: nea to @
Edited by vanowm
Found a solution
  • vanowm changed the title to break a line at a nearest point works only with manual command
This is why i try to stay away from using (command  it doesn't always  behave like it does when your typing in commands. I don't remember the command but I found out that using (vla-SendCommand worked when (command was giving me issues.
(vla-sendcommand (vla-get-ActiveDocument (vlax-get-acad-object)) "break" pause "f" pause "@")
Quote
Chalk it up to you have a setting that is set different or AutoDesk programmed the break command updated/changed since 2002.
(command "break" pause "f" pause "@") worked for me in 2019 BricsCAD.
(command "break" pause "f" pause "@") works on AutoCAD 2022 for me as well.
I've already found a few other commands that are different when used (command). I.e. fillet, note the options:
Command: fillet
Current settings: Mode = TRIM, Radius = 0.0000
Select first object or [Undo/Polyline/Radius/Trim/Multiple]:
Command: (command "fillet")
nil
Select first object or [uNdo/Polyline/Radius/Trim/mUltiple]:
For fillet if I remember correctly fillet supports various methods in lisp.
Just looked through code I have and there are 3 different ways.
pt1 pt2,
ent pt,
ent ent.
I think it depends on what your filleting like a pline and a line.
Yes, but why in the world would they change Undo to uNdo and Multiple to mUltiple
It wasn't the case in AC2002
Command: fillet
nil
(initcommandversion)
(command "_.fillet")
;; Select first object or [Undo/Polyline/Radius/Trim/Multiple]:
