Deepak Raman Posted April 2, 2023 Posted April 2, 2023 Hi all, Clicking on multileader, it starts with Mtext window instead of the arrow (leader) which is annoying; how to change back to original sequence? although I don't remember changing anything for the MLEADER style anytime.. any info appreciated..!! thanks in advance.. Quote
CyberAngel Posted April 3, 2023 Posted April 3, 2023 Check these system variables: PICKFIRST should be 1 DBLCLKEDIT should be on noun/verb selection should be on Check your UI behavior, default double-click should be, well, whatever you were doing, instead of TEXTEDIT. If that doesn't help, please provide more information. Welcome to the forum! 1 Quote
Deepak Raman Posted April 10, 2023 Author Posted April 10, 2023 On 03/04/2023 at 15:03, CyberAngel said: Check these system variables: PICKFIRST should be 1 DBLCLKEDIT should be on noun/verb selection should be on Check your UI behavior, default double-click should be, well, whatever you were doing, instead of TEXTEDIT. If that doesn't help, please provide more information. Welcome to the forum! Hi there.. thank you for your time and response. But problem not solved, though i checked PICKFIRST-1, DBLCLKEDIT-on ... Pls check the video attached, waiting for your further valuable advice.. WhatsApp Video 2023-04-10 at 9.20.40 AM.mp4 Quote
SLW210 Posted April 11, 2023 Posted April 11, 2023 Try looking at your commandline, the option is there to set it back to Leader Arrowhead first or hit the down arrow on the keyboard to bring up options. 1 Quote
