BIGAL Posted April 2, 2023 Posted April 2, 2023 So if a object is on layer 1 and its color is by ByLayer, you want it now on layer2 but with color of layer 1 or if its not bylayer the color should just maintain anyway. Quote
Elektrik Posted April 2, 2023 Author Posted April 2, 2023 8 hours ago, BIGAL said: So if a object is on layer 1 and its color is by ByLayer, you want it now on layer2 but with color of layer 1 or if its not bylayer the color should just maintain anyway. Yes, a object is on layer 1 and its color is by ByLayer, I want it now on layer2 but with color of layer 1. Quote
abra-CAD-abra Posted April 2, 2023 Posted April 2, 2023 Elektrik, this VLA approach should set you in the right direction. No error trapping. (defun C:LAYER-TEST ( / doc lay suf sel lyr col ) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (setq lay (vla-get-layers doc)) (setq suf "_1") (if (ssget) (progn (vlax-for x (setq sel (vla-get-activeselectionset doc)) (cond ((not (tblsearch "Layer" (setq lyr (strcat (vla-get-layer x) suf)))) (vla-put-color (vla-add lay lyr) (setq col (vla-get-color (vla-item lay (vla-get-layer x)))) ) (vla-put-layer x lyr) ) ( t (if (not (= (vla-get-color (vla-item lay lyr)) col)) (progn (vla-put-color (vla-item lay lyr) col) (vla-put-layer x lyr) ) ) ) ) ) (vla-delete sel) ) ) (princ) ) (princ) 1 Quote
