Create Temp DCL File Error missing semicolon
(defun c:test2 ()	;Command test2
(vl-load-com) 		;load VLISP
  (setq tempname (vl-filename-mktemp "temp.dcl") filen (open tempname "w")) ;create temporary dcl
  (foreach stream
    '("kzzbss:dialog{"
      "\n  label="temporary dialog";"
      "\n  :popup_list{key="tag";label="Attributes:";list="List1\\nList2\\nList3\\nList4\\nList5\\nList6\\nList7\\nList8";}"
      "\n  :edit_box{key="str"; label="value:";}"
      "\n  ok_cancel;}")
  (princ stream filen))	;Write the above data in temporary dcl
  (close filen)		;close file
  (setq dclname tempname)
  (setq dcl_re (load_dialog dclname)) 			;load temporary dcl
  (if (not (new_dialog "kzzbss" dcl_re)) (exit))
  (action_tile "accept" "(OKaction)(done_dialog 1)")	;Define the action for the OK button
  (action_tile "cancel" "(done_dialog)")
  (setq std (start_dialog))
  (unload_dialog dcl_re)		;unload_dialog
  (vl-file-delete dclname)		;Delete temporary dcl files
  (if (= std 1) (run the program))	;run
error in above program
You need to add a backslash before each double quote when you include a string into another.
'("kzzbss :dialog{"
      "label=\"temporary dialog\";"
      ":popup_list{key=\"tag\";label=\"Attributes:\";list=\"List1\\nList2\\nList3\\nList4\\nList5\\nList6\\nList7\\nList8\";}"
      ":edit_box{key=\"str\"; label=\"value:\";}"
      "ok_cancel;}")
  • Thanks 1
'("kzzbss :dialog{"
      "ok_cancel;}")
thanks its working
Just a comment I use a library List box.lsp making a  list dcl then you can use it in any code with out having to copy and edit the source into every code. Its just 2 lines of code, plus list. This version matches what was provided by Lee-mac. I have another similar. You could do it to what you have done.
(setq lst (list "l1" "l2" "l3" "l4" "L5"))
(if (not LM:listbox)(load "ListBoxV1-2.lsp")) ; loads the lisp if not already loaded
(setq ans (LM:listbox "please choose " lst 1))
Edited by BIGAL
  • Thanks 1
