Hi
I have this code, that checks every layer that starts with the name A-
(if (setq ssL (ssget "_X" (list (cons 8 "A-*") '(410 . "Model"))))
	;do something
This works fine, but I want to make some exceptions in the selection of layers.
EX:
Select  ( A-*)  except (A-4) except (A-5)
There are a lot of layers starting with A- (as you can imagine) and i only want to skip a few.
Looked att Lee Macs code here:
http://www.lee-mac.com/ssget.html#:~:text=Logical Not,256 (ByLayer).
And it's something like this I´m looking for, but I can't make it work for the list selection.
Don't know what your where trying but this should work.
(if (setq ssL (ssget "_X" '((8 . "A-*")(-4 . "<NOT")(8 . "A-4,A-5")(-4 . "NOT>")(410 . "Model"))))
   ;Do stuff
-Edit
for each layer you want to ignore just add it into the middle (8 . "layer1,layer2,layer3,layer4,layer5")
Also worth a look.
(if (setq ssL (ssget "_X" '((8 . "A-*")(-4 . "<NOT")(8 . "A-#")(-4 . "NOT>")(410 . "Model"))))
This would ignore layers A-0, A-1, A-2, A-3, A-4, A-5, A-6, A-7, A-8, & A-9
Edited by mhupp
   ;Do stuff
-Edit
Also worth a look.
I forgot to say that i need ssL to be a list,  else I need to change a lot of stuff 🙄
(setq l '("A-4" "A-5"))
(setq ssl (ssget "_X"
		 (list '(8 . "A-*")
		       '(-4 . "<NOT")
		       (cons 8 (apply 'strcat (mapcar '(lambda (x) (strcat x ",")) l)))
		       '(-4 . "NOT>")
		       '(410 . "Model")
  • Like 3
		 (list '(8 . "A-*")
		       '(-4 . "<NOT")
		       '(-4 . "NOT>")
		       '(410 . "Model")
Woaw that is just great, thanks alot! 👌
