How to pop up an alert with a TEXT/MTEXT's property values in AutoLISP?
AeJay
I am trying to create a function wherein it would ask a user to select a text (either TEXT/MTEXT) then it would simply alert the value of that TEXT/MTEXT's color, layer, contents, and height which are stated in the properties.
I have this code but an error of "Program ERROR: bad argument type: stringp nil"
				(defun c:textprop()
				  (setq textobj (car (entsel "\nSelect text or mtext: ")))
				  (if (and textobj (member (cdr (assoc 0 (entget textobj))) '("TEXT" "MTEXT")))
					  (setq textinfo (entget textobj))
					  (setq textvalue (assoc 1 textinfo))
					  (setq textheight (assoc 40 textinfo))
					  (setq textcolor (assoc 62 textinfo))
					  (setq textlayer (assoc 8 textinfo))
					  (alert (strcat "Text contents: " textvalue "\nHeight: " (rtos textheight) "\nColor: " textcolor "\nLayer: " textlayer)))
					(alert "Please select a valid text or mtext object."))
				  (princ))
Got it to work. It seems that colors appear as text in the properties tab but are actually stored as numbers, like how Cyan is equal to 4. Thus, I had to use itoa to convert the integer of Cyan(4) into a string. But how about if I wanted it to output "Cyan" instead of the integer "4"?
				(defun c:selecttext(/ textinfo textvalue textheight textcolor textlayer textobj)
				  (if (and textobj (member (cdr (assoc 0 (entget textobj))) '("TEXT" "MTEXT" "ATTRIB")))
					  (setq textinfo (cdr (entget textobj)))
					  (setq textvalue (cdr (assoc 1 textinfo)))
					  (setq textheight (cdr (assoc 40 textinfo)))
					  (setq textcolor (cdr (assoc 62 textinfo)))
					  (setq textlayer (cdr (assoc 8 textinfo)))
					  (alert (strcat "Text contents: " textvalue "\nHeight: " (rtos textheight) "\nColor: " (itoa textcolor) "\nLayer: " textlayer)))
				  (princ))
Ok my take on question 1 redid code to cater for text color is by layer. There is no 62 dxf for bylayer.
(defun c:textprop( / textobj textinfo textvalue textcolor textlayer)
(setq textobj (ssname (ssget "_+.:E:S" (list (cons 0 "TEXT,MTEXT"))) 0))
(if (= textobj nil)
  (alert "A text type object was not picked ")
    (if (= (setq textcolor (cdr (assoc 62 textinfo))) nil)
      (alert (strcat "Text contents: " textvalue "\nHeight: " (rtos textheight 2 1) "\nColor: " "Bylayer" "\nLayer: " textlayer))
      (alert (strcat "Text contents: " textvalue "\nHeight: " (rtos textheight 2 1) "\nColor: " (rtos textcolor 2 0) "\nLayer: " textlayer))
(c:textprop)
Re do a color need a cond. So replace the 2nd Alert with a cond, have a go. Inside a progn so 2nd alert still works inside that progn.
Noticed the 1st attempt did not have the cdr's.
If your happy can use "*TEXT" but it will find Dtext and Rtext. But we never used them so maybe ok.
I have a get properties lisp, just pick an object and you determine what you want returned so for say a circle would be centre point and radius, like you for a text return what is needed, there is another lisp out there that returns more items than I have done.
Pline line arc props.lsp
Edited by BIGAL
  • Thanks 1
(if (= textobj nil)
(c:textprop)
Regarding int to color. I am again having the stringp nil error with this code I tried:
(defun c:textprop( / textobj textinfo textvalue textcolor textlayer nColor)
(if (= textobj nil)
      (alert (strcat "Text contents: " textvalue "\nHeight: " (rtos textheight 2 1) (setq nColor(itoa textcolor))
      (cond
		((= nColor 1)(strcat "\nColor: " "RED"))
		((= nColor 2)(strcat "\nColor: " "YELLOW"))
		((= nColor 3)(strcat "\nColor: " "GREEN"))
		((= nColor 4)(strcat "\nColor: " "CYAN"))
		((= nColor 5)(strcat "\nColor: " "BLUE"))
		((= nColor 6)(strcat "\nColor: " "MAGENTA"))
		((= nColor 7)(strcat "\nColor: " "WHITE"))
I also tried with same error of stringp nil:
(defun c:textpropz( / textobj textinfo textvalue textcolor textlayer nColor)
(if (= textobj nil)
      (cond
		((equal nColor 1)("\nColor: " "RED"))
		((equal nColor 2)("\nColor: " "YELLOW"))
		((equal nColor 3)("\nColor: " "GREEN"))
		((equal nColor 4)("\nColor: " "CYAN"))
		((equal nColor 5)("\nColor: " "BLUE"))
		((equal nColor 6)("\nColor: " "MAGENTA"))
		((equal nColor 7)("\nColor: " "WHITE"))
Edited by AeJay
Coming along way @AeJay for only 22 posts.
to simplify things
(if (= textobj nil)
(if (setq textobj (ssname (ssget "_+.:E:S" (list (cons 0 "TEXT,MTEXT"))) 0))
or
(if textobj
with two or more string side by side you can just join them into one
...(rtos textheight 2 1) "\nColor: " "Bylayer" "\nLayer: " textlayer))
...(rtos textheight 2 1) "\nColor: Bylayer \nLayer: " textlayer))
I think your code would error or not display if selecting text that its color isn't 1-7
again from above  join strings into one.
can just be
((= nColor 1) "\nColor: RED")
My code keeps everything in a list. so their is only the selection set and the data variable.
Entget
((-1 . <Entity name: 3eed7ec0>) (0 . "TEXT") (5 . "71") (330 . <Entity name: 3e488ae0>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (62 . 1) (370 . -1) (100 . "AcDbText") (10 5.59944594793636 4.30743710947954 0.0) (40 . 0.2) (1 . "asdfasdfsdaf") (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . "Standard") (71 . 0) (72 . 0) (11 0.0 0.0 0.0) (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 0))
Becomes
(8 . "0") (62 . 1) (40 . 0.2) (1 . "asdfasdfsdaf")
Then values are put into list data
'("0" 1 0.2 "asdfasdfsdaf")
'(Layer color height textstring)
finally
(defun c:ttp (/ ss data)
  (while (setq ss (ssget "_+.:E:S" '((0 . "TEXT,MTEXT")))) ;while to allow you to keep selecting in the same command.
    (setq data (mapcar 'cdr (vl-remove-if-not '(lambda (x) (or (= (car x) 1) (= (car x) 40) (= (car x) 62) (= (car x) 8))) (entget (ssname ss 0)))))
    (if (= (length  data) 3)
      (alert (strcat "Text: " (last data) "\nHeight: " (rtos (cadr data) 2 2) "\nColor: ByLayer \nLayer: " (car data)))
      (alert (strcat "Text: " (last data) "\nHeight: " (rtos (caddr data) 2 2)
        (cond
          ((= (cadr data) 1) "\nColor: RED")
          ((= (cadr data) 2) "\nColor: YELLOW")
          ((= (cadr data) 3) "\nColor: GREEN")
          ((= (cadr data) 4) "\nColor: CYAN")
          ((= (cadr data) 5) "\nColor: BLUE")
          ((= (cadr data) 6) "\nColor: MAGENTA")
          ((= (cadr data) 7) "\nColor: WHITE")
          (t (strcat "\nColor: " (itoa (cadr data)))) ;their are over 256 colors so if it isn't the first 7 display number
        "\nLayer: " (car data)))
Edited by mhupp
  • Thanks 1
to simplify things
(if (= textobj nil)
or
(if textobj
can just be
Entget
Becomes
finally
        (cond
Such a detailed answer, thank you so much!
