VAC Posted March 28, 2023 Share Posted March 28, 2023 Hi, I have two files. Both were created from the original prototype not long ago. Dynamic blocks are placed in both. If I copy the blocks in the first file to the clipboard (CTRL+C), then after trying to insert them into this same file or into the second file, only some of them change their shape (directions of reference lines). If I do the same thing the other way around (copy from file 2), this doesn't happen. Can someone explain this to me? And how to prevent it? Thanks file1_OK.dwg file2_KO.dwg Quote Link to comment Share on other sites More sharing options...
nod684 Posted March 28, 2023 Share Posted March 28, 2023 Looks fine on my side... Sometimes changing the visibility solves the issue. then change it back to its previous state.... Quote Link to comment Share on other sites More sharing options...
VAC Posted March 28, 2023 Author Share Posted March 28, 2023 Sorry, I reversed the description. File 1 is OK, file 2 is bad. It is still really fine on your side in the second KO file? Blocks with number 55 change their reference lines. Changing visibility did nothing. Quote Link to comment Share on other sites More sharing options...
VAC Posted March 31, 2023 Author Share Posted March 31, 2023 Nobody knows why and how to solve it? Quote Link to comment Share on other sites More sharing options...
ColinPearson Posted May 3, 2023 Share Posted May 3, 2023 I don't get anything weird either. Quote Link to comment Share on other sites More sharing options...
