Count Attribute Values
itacad
  • 1 year later...
Good morning, I noticed that I have not received a response to this topic... I will continue in more detail.
The lisp Count Attribute Values is very powerful for making checks, unfortunately it has the limitation that it does not distinguish between attributes in the count... let me explain better, I would need to do the counting by values but associating it with the attribute label, that is, the same value of different attributes should not be counted together.
I hope that Mr. Lee Mac will read this topic
@itacad
You can simply contact Mr. Lee Mac directly on his website if you want to ask him for changes to his code: https://lee-mac.com/contact.html
This program is very old (13 years in fact); I'll look to update it to incorporate a tag prompt (if multiple tags are found in the selection) as & when I have time.
I've now incorporated this feature into Version 1.1.
  • Like 2
Hi Mr. Mac Lee...the link still refers to version 1.0 and the download links on the page don't work...on the previous page it is actually indicated as updated
https://lee-mac.com/programs.html
I apologize for the insistence, it is due to the daily use I make of this lisp.
Thanks again
