itacad Posted March 26, 2023 Posted March 26, 2023 Hi, during a search I found this very powerful lisp by Lee Mac http://lee-mac.com/countattributevalues.html It's the fastest solution I've found for a problem I face every day. I ask if it can be modified, allowing the choice of the attribute on which to apply the lisp Tnak you in advance Quote
itacad Posted October 31, 2024 Author Posted October 31, 2024 Good morning, I noticed that I have not received a response to this topic... I will continue in more detail. The lisp Count Attribute Values is very powerful for making checks, unfortunately it has the limitation that it does not distinguish between attributes in the count... let me explain better, I would need to do the counting by values but associating it with the attribute label, that is, the same value of different attributes should not be counted together. I hope that Mr. Lee Mac will read this topic Quote
pkenewell Posted November 1, 2024 Posted November 1, 2024 On 10/31/2024 at 1:00 PM, itacad said: Good morning, I noticed that I have not received a response to this topic... I will continue in more detail. The lisp Count Attribute Values is very powerful for making checks, unfortunately it has the limitation that it does not distinguish between attributes in the count... let me explain better, I would need to do the counting by values but associating it with the attribute label, that is, the same value of different attributes should not be counted together. I hope that Mr. Lee Mac will read this topic Expand @itacad You can simply contact Mr. Lee Mac directly on his website if you want to ask him for changes to his code: https://lee-mac.com/contact.html Quote
Lee Mac Posted November 1, 2024 Posted November 1, 2024 This program is very old (13 years in fact); I'll look to update it to incorporate a tag prompt (if multiple tags are found in the selection) as & when I have time. 1 Quote
Lee Mac Posted November 3, 2024 Posted November 3, 2024 On 11/1/2024 at 3:17 PM, Lee Mac said: This program is very old (13 years in fact); I'll look to update it to incorporate a tag prompt (if multiple tags are found in the selection) as & when I have time. Expand I've now incorporated this feature into Version 1.1. 2 Quote
itacad Posted November 7, 2024 Author Posted November 7, 2024 Hi Mr. Mac Lee...the link still refers to version 1.0 and the download links on the page don't work...on the previous page it is actually indicated as updated https://lee-mac.com/programs.html I apologize for the insistence, it is due to the daily use I make of this lisp. Thanks again Quote
itacad Posted November 8, 2024 Author Posted November 8, 2024 Fantastic! thank you thank you thank you! Quote
