G.Aquarius Posted March 19, 2023 Share Posted March 19, 2023 (edited) Hello, new to LISP here. The title might make it sound like the solution would be a simple if loop but sadly it's a tad more complicated. Here's what I'm trying to do: I have a title block, it has an attribute that states the revision number. I got a variable (RevLatest) set in my code to read that revision number, say "F.0" for example. Now, I have a revision table, with 6 rows and 5 columns, the first column stating the previous and current revisions (A.0 to F.0). The revision table is a block with the information stored as attributes. The attributes for the revision numbers are named Rev_1, Rev_2, and so on. The same goes for the other info stored in that block, for eg., Rev_Description1-6, Rev_Date1-6, and so on. I want my program to check the first column of the revision table, check if it matches the number in the title block (F.0 in this example), and then read the information in that row only. So, if the title block revision is RB.0, I want the program to read the attributes' RevDescription2, RevDate2, etc. information. Here's the code I have, but I'm getting this error " ; error: bad function: "F.0" " (while (<= cntr 6) (if (= (getpropertyvalue obj2 (strcat "REV_" (rtos cntr 2 0))) RevLatest) (progn (setq RevIFC (RevLatest)) (setq DescIFC (getpropertyvalue obj2 (strcat "REV_DESCRIPTION" (rtos cntr 2 0)))) (setq DateIFC (getpropertyvalue obj2 (strcat "REV_DATE" (rtos cntr 2 0)))) ) ) (setq cntr (+ cntr 1)) ) obj2 is the block name for the revision table Please advise. Thanks for the help. Edited March 19, 2023 by G.Aquarius Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 19, 2023 Share Posted March 19, 2023 Ok 1st up posting a dwg is always best as it shows what your working with. I don't use set or get property as not supported in my Bricscad. Just a comment I would probably convert the table block to a list of attributes easier to loop through. The other is I use creation order of blocks a lot as don't need to worry about tag names. If your creating a dwg index I make a "TABLE" it is created by reading from the layouts the title block attributes and populates a "TABLE" so if change revisions just delete and create again. Used this on 88 layouts dwg. Its fast. 1 Quote Link to comment Share on other sites More sharing options...
G.Aquarius Posted March 20, 2023 Author Share Posted March 20, 2023 Figured out why it's not working. I have an extra set of brackets around RevLatest, which was causing the issue. Remove that and it works perfectly. (setq RevIFC (RevLatest)) @BIGAL Thanks for the suggestions. I'll make sure to have a dwg attached next time I ask something Quote Link to comment Share on other sites More sharing options...
