Polyline and hatching with AutoLISP
Hello everyone,
I want to create a program that draws a polyline with hatching and hatching scale, here is the script:
(defun kb_sc (/ sc_ent sc_sc)
  ; select area
  (command "_pline")
  (setq sc_ent (entlast))
  ; scale
  (princ "\nEnter scale:")
  (setq sc_sc (getint))
  ; hatching
  (setq oldHPNAME (getvar "HPNAME"))
  (setq oldHPSCALE (getvar "HPSCALE"))
  (setvar "HPNAME" "ANSI31")
  (setvar "HPSCALE" sc_sc)
  (command "-HATCH" "S" sc_ent "" "")
  (setvar "HPNAME" oldHPNAME)
  (setvar "HPSCALE" oldHPSCALE)
However, there is a problem. Can you provide a solution so that this program can run properly?
Thank You
Edited by SLW210
Added Code Tags!
I've made it more readable and improved coding, but haven't tested...
Tell us how it passed test(s)...
(defun c:kb_sc ( / *error* sc_ent sc_sc oldhpname oldhpscale )
  (vl-load-com) ; enable VisualLisp extensions
  ; error handler
  (defun *error* ( m )
    (if oldhpname
      (setvar (quote hpname) oldhpname)
    (if oldhpscale
      (setvar (quote hpscale) oldhpscale)
    (if m
      (prompt m)
  ; select area
  (command "_.PLINE")
  (while (< 0 (getvar (quote cmdactive)))
    (command "\\")
  (if (not (vlax-curve-isclosed sc_ent))
    (vla-put-closed (vlax-ename->vla-object sc_ent) :vlax-true)
  ; scale
  (initget 7)
  (setq sc_sc (getdist "\nPick or specify scale : "))
  ; hatching
  (setq oldhpname (getvar (quote hpname)))
  (setq oldhpscale (getvar (quote hpscale)))
  (setvar (quote hpname) "ANSI31")
  (setvar (quote hpscale) sc_sc)
  (command "_.HATCH" "_S" sc_ent "" "")
  (*error* nil)
HTH.
M.R.
Edited by marko_ribar
Yup, a quick description of the problem would help
I found this code here
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/entmake-hatch-with-base-point-or-object-polyline-entity-name/m-p/8703197#M383362
I adapted it to do what you asked.
I made 2 commands: 1 that selects existing polylines ( SPH ), 1 where you make new polylines ( MPH ).
;;;; https://www.cadtutor.net/forum/topic/77129-polyline-and-hatching-with-autolisp/
;; User makes a polyline by selecting points.  The polyline is auto closed, a hatch is drawn inside
;; Make Polyline Hatch
(defun c:mph ( / ss sc pp pt pts ln ls pline)
	(setq sc (getreal "\nScale: "))
	(if (= 0.0 sc)
		(setq sc 1.0)
	(prompt "\nSelect points to make a Closed Polyline.  Press enter to close the polyline: ")
	(setq pts (list))
	(setq ls (list))
	(setq pt (getpoint "\nPoint 1: "))
	(setq pp pt)
	(setq pts (append pts (list pt)))
	(while (setq pt (getpoint pt "\nPoint: "))
		;; draw temporary line
		(setq ls (append ls (list (drawLine pp pt))))
		(setq pp pt)
	(setq pline (drawLWPoly pts 1))
	;; delete temporary lines
	(foreach ln ls
		(entdel ln)
	(hatch_closed_polyline (ssadd pline) sc)
;; https://www.cadtutor.net/forum/topic/18257-entmake-functions/
(defun drawLine (p1 p2)
 (entmakex (list (cons 0 "LINE")
                 (cons 10 p1)
                 (cons 11 p2)))
(defun drawLWPoly (lst cls)
 (entmakex (append (list (cons 0 "LWPOLYLINE")
                         (cons 100 "AcDbEntity")
                         (cons 100 "AcDbPolyline")
                         (cons 90 (length lst))
                         (cons 70 cls))
                   (mapcar (function (lambda (p) (cons 10 p))) lst)))
;;;; user selects existing polylines; a hatch will be drawn inside
;; Select Polyline Hatch
(defun c:sph ( / ss sc)
	(prompt "\nSelect Closed Polylines to Hatch: ")
	(while (setq ss (ssget '((0 . "LWPOLYLINE"))))
		(hatch_closed_polyline ss sc)
		;;(entmakex-hatch hList 0.0 "ANSI31" 1.0)
;; slightly modified from this code:
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/entmake-hatch-with-base-point-or-object-polyline-entity-name/m-p/8703197#M383362
(defun hatch_closed_polyline (ss sc /  cnt e hList)
	(if (= 0.0 sc)
		(setq sc 1.0)
(setq cnt (sslength ss))
(while (<= 0 (setq cnt (1- cnt)))
  (setq e (ssname ss cnt))
  (if (setq tmp (CreateHatchList e))
    (setq hList (cons tmp hList))
  );if
);while
(setq hList (reverse hList))
(if (entmakex-hatch hList 0.0 "ANSI31" sc)
  (prompt "\nSuccess!")
  (prompt "\n...Failure.")
);if
);defun
(defun CreateHatchList (e / i j pList found)
(foreach i (entget e)
  (if (= 10 (car i))
      (setq pList (cons i pList))
      (setq found nil j (member i (entget e)))
      (while (and (not found) (< 0 (length j)))
	(if (= 42 (car (car j)))
	  (setq pList (cons (car j) pList) found t)
	);if
	(setq j (cdr j))
      );while
    );progn
  );if
);foreach
(reverse pList)
);defun
(defun entmakex-hatch (l a n s)
 ;; By ElpanovEvgeniy
 ;; L - list point
 ;; A - angle hatch
 ;; N - name pattern
 ;; S - scale
 ;; return - hatch ename
 (entmakex
  (apply
   'append
   (list
    (list '(0 . "HATCH") '(100 . "AcDbEntity") '(410 . "Model") '(100 . "AcDbHatch")
          '(10 0.0 0.0 0.0) '(210 0.0 0.0 1.0)
          (cons 2 n)
          (if (= n "SOLID")
           '(70 . 1)
           '(70 . 0)
          ) ;_  if
          '(71 . 0)
          (cons 91 (length l))
    ) ;_  list
    (apply 'append
           (mapcar '(lambda (a)
                     (apply 'append
                            (list (list '(92 . 7) '(72 . 1) '(73 . 1) (cons 93 (/ (length a) 2)))
				  (mapcar '(lambda (b) b) a)
                                  '((97 . 0))
                            ) ;_  list
                     ) ;_  apply
                    ) ;_  lambda
                   l
           ) ;_  mapcar
    ) ;_  apply
    (list '(75 . 0) '(76 . 1) (cons 52 a) (cons 41 s) '(77 . 0) '(78 . 1) (cons 53 a)
          '(43 . 0.) '(44 . 0.) '(45 . 1.) '(46 . 1.) '(79 . 0) '(47 . 1.) '(98 . 2)
          '(10 0. 0. 0.0) '(10 0. 0. 0.0) '(451 . 0) '(460 . 0.0) '(461 . 0.0) '(452 . 1)
          '(462 . 1.0) '(453 . 2) '(463 . 0.0) '(463 . 1.0) '(470 . "ANSI31")
    ) ;_  list
   ) ;_  list
  ) ;_  apply
 ) ;_  entmakex
) ;_  defun
(princ "\nCOMMAND MPH: Make Polyline Hatch.")
(princ "\nCOMMAND SPH: Select Polyline Hatch.")
Hi Emmanuel,
Thank you for this lisp. In the second lisp (sph), instead of selecting the polylines,
i don't know if we can selected only one polyline and the others polylines (included circles..) which have the SAME LAYER do the same job!
Sorry for my english!
Many thanks!
Circle won't work.  The code asks for a point list; so nothing round.
It will work for all closed polylines.
Add this to the rest of my previous code
;; Select Polyline Hatch Layer
;; user selects an object.  All closed polylines on the layer of the
;;    selected object gets selected and a hatch is drawn inside
(defun c:sphl ( / obj layer ss sc i)
	(prompt "\nSelect Closed Polylines to Hatch. All closed polylines on the layer of the selected object \ngets selected and a hatch is drawn inside: ")
	(setq obj (car (entsel "\nSelect object: ")))
	(setq layer (cdr (assoc 8 (entget obj))))
	(setq ss (ssget "_X" (list (cons 0 "LWPOLYLINE") (cons 70 1) (cons 8 layer) )))
	(setq i 0)
	(repeat (sslength ss)
		(hatch_closed_polyline (ssadd (ssname ss i)) sc)
		(setq i (+ i 1))
It's OK for "ANSI31" pattern. Is it possible to do that for the pattern by default (pattern, angle, scale..by default)?
Many thanks!
Try this:
replace (don't forget the ')
'(470 . "ANSI31")
by
(cons 470 (getvar "HPNAME"))
Sorry, I can't see the line to be replaced?!
It is at the end of here:
find' would get that.
Just replace the part shown
It seems not working. Error! Can you please put it together.
thanks!
For Emmanuel, i replace '(470 . "ANSI31")by (cons 470 (getvar "HPNAME")), it seems to be like before that's to say "ANSI 31" pattern and not model hatching by default.
For Steven P, i replace (list '(75 . 0) '(76 . 1) (cons 52 a) (cons 41 s) '(77 . 0) '(78 . 1) (cons 53 a) '(43 . 0.) '(44 . 0.) '(45 . 1.) '(46 . 1.) '(79 . 0) '(47 . 1.) '(98 . 2) '(10 0. 0. 0.0) '(10 0. 0. 0.0) '(451 . 0) '(460 . 0.0) '(461 . 0.0) '(452 . 1) '(462 . 1.0) '(453 . 2) '(463 . 0.0) '(463 . 1.0) '(470 . "ANSI31") and the result is error!
Any help would be appreciated!
