Pick viewport and draw grid line orthoview plant 3d
Good Night everyone, i am new on this C# world, i need to do run in Auto cad Plant 3D the following.
1- i will make 3D model containing navite grid line from struct grid.
2- I Will generate view ports for Orthoviews
3- Now I want to pick the view port and my C# code recognizes the gridline and draw grid bubbles and position them in my drawing.
I've make the code but it says a lot of errors, i get no clue what is going on. does anybody can help please?
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using Autodesk.ProcessPower.PnP3dObjects;
public void DrawGridLine()
    Document acDoc = Application.DocumentManager.MdiActiveDocument;
    Database acCurDb = acDoc.Database;
    Editor acEd = acDoc.Editor;
    // Select viewport
    PromptEntityOptions peo = new PromptEntityOptions("\nSelect viewport: ");
    peo.SetRejectMessage("\nPlease select a valid viewport.");
    peo.AddAllowedClass(typeof(Viewport), true);
    PromptEntityResult per = acEd.GetEntity(peo);
    if (per.Status != PromptStatus.OK)
        acEd.WriteMessage("\nError selecting viewport.");
        return;
    Viewport vp = (Viewport)per.ObjectId.GetObject(OpenMode.ForWrite);
    // Draw grid line
    Gridstruct gs = new Gridstruct();
    gs.LayerName = "GRID";
    gs.GridColor = Color.FromColorIndex(ColorMethod.ByAci, 8);
    gs.GridLineStyle = LineStyle.Solid;
    gs.GridLineWeight = LineWeight.LineWeight015;
    gs.GridSpacing = 100;
    double x1 = vp.ViewCenter.X - vp.Width / 2.0;
    double y1 = vp.ViewCenter.Y - vp.Height / 2.0;
    double x2 = vp.ViewCenter.X + vp.Width / 2.0;
    double y2 = vp.ViewCenter.Y + vp.Height / 2.0;
    Point3d startPoint = new Point3d(x1, y1, 0);
    Point3d endPoint = new Point3d(x2, y1, 0);
    gs.CreateGridLine(startPoint, endPoint, vp.NumberOfColumns);
    acCurDb.AddToModelSpace(gs);
    acDoc.TransactionManager.QueueForGraphicsFlush();
    acDoc.TransactionManager.FlushGraphics();
