Radu Iordache Posted March 10, 2023 Posted March 10, 2023 Hello, can someone help with a simple lisp to get the coordinates of the start point of a lwpolyline in the form Y,X (north,east) and store them in a variable? Thanks a lot! Quote
Tharwat Posted March 10, 2023 Posted March 10, 2023 You can use the vlax-curve-getstartpoint or the first DXF 10 if you entget the entity. Quote
BIGAL Posted March 10, 2023 Posted March 10, 2023 Following on from Tharwat suggestion. (setq ent (entsel "\nPick a pline ")) ; pick pline (setq entg (entget (car ent))) ; get entity values (setq pt (cdr (assoc 10 entg))) ; get 1st point or (setq obj (vlax-ename->vla-object (car (entsel "\nPick a pline ")))) ; pick pline (setq start (vlax-curve-getstartPoint obj)) ; get 1st point Quote
Tharwat Posted March 11, 2023 Posted March 11, 2023 It is not necessarily / required to convert an entity to vla-object when using it with any of vlax-curve* functions. 1 Quote
ronjonp Posted March 15, 2023 Posted March 15, 2023 On 3/11/2023 at 7:13 AM, Tharwat said: It is not necessarily / required to convert an entity to vla-object when using it with any of vlax-curve* functions. Converting to vla-object then using curve functions is also quite a bit slower. (setq e (car (entsel))) (setq o (vlax-ename->vla-object e)) (benchmark '((vlax-curve-getStartPoint e)(vlax-curve-getStartPoint o))) ;;;<Entity name: 1e9f2363150> ;;;#<VLA-OBJECT IAcadLWPolyline 000001e9df9c2dc8> Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s): ;;; ;;; (vlax-curve-getStartPoint E).....1781 / 1.71 <fastest> ;;; (vlax-curve-getStartPoint O).....3047 / 1.00 <slowest> ;;; ;;;---- Benchmark Utility: In memory of Michael Puckett ---- ;;; ;;;; 3 forms loaded from #<editor "<Untitled-0> loading..."> 1 Quote
Steven P Posted March 15, 2023 Posted March 15, 2023 Depends on the function of course, if you are processing a lot of lines then program speed can be an issue, only a few lines and the slowest thing is the user and their mouse. I'd go first off with what I know works, and then speed it up if necessary Quote
mhupp Posted March 16, 2023 Posted March 16, 2023 (edited) 11 hours ago, ronjonp said: Converting to vla-object then using curve functions is also quite a bit slower. Even tho the documentation says vlax-curve-getstartPoint works with vla-objects you can feed it entity names as well. i think this works with all vlax-curve functions. -edit Tharwat-ed (setq SPT (vlax-curve-getstartPoint (car (entsel "\nPick a pline ")))) ; get 1st point (vl-cmdf "_.Circle" "_non" SPT "0.25") Edited March 16, 2023 by mhupp Quote
