"Mitch" Posted March 8, 2023 Posted March 8, 2023 I received a drawing that contains a layer in the manager box. But when I attempted to Quick Select that layer, the result returns as "0" and this same layer cannot be deleted, since the message tells me that layers with objects cannot be deleted. I thawed all layers and still get "0" and the layer won't delete. This should mean that the layer is hidden inside a block. This drawing has several hundreds of blocks! Is there an application within AutoCAD that will reveal to me which block that layer is in? Quote
BIGAL Posted March 8, 2023 Posted March 8, 2023 So you purged all the blocks 1st ? That reduces the total number of blocks left need to do a couple of times. If its a CIV3D dwg it can have styles in it with layers and purge will not remove unused. PURGESTYLES but thats a CIV3D command. Did you google "get entities in block autocad lisp" lots of answers. Quote
CyberAngel Posted March 9, 2023 Posted March 9, 2023 My first strategy would be to freeze all other layers. With any luck, you'll see the bogus item immediately. When you select it, you'll see the block it belongs to. My next strategy would be to change the color of that layer to some bright color that will stand out. If there's an object in a block on that layer, and its color isn't overridden, you should be able to spot it quickly. Beyond that, I'd have to think that it's an End Definition object. When you create a block, there's a phantom object on the current layer that gets tacked onto the block definition. You can't see it, you can't select it, you'd never know it was there except in this case. LAYDEL should get rid of it. Quote
tombu Posted March 10, 2023 Posted March 10, 2023 As I generally prefer block entities to be on layer 0 anyway I'd simply merge that layer with layer 0 and be done with it. Quote
Quango1 Posted March 31, 2023 Posted March 31, 2023 I have a LISP Routine that I found on here that sets all objects within blocks in the drawing to layer 0 then i purge out those layers. (defun c:norm (/ *error* adoc lst_layer func_restore-layers) (defun *error* (msg) (func_restore-layers) (vla-endundomark adoc) (princ msg) (princ) ) ;_ end of defun (defun func_restore-layers () (foreach item lst_layer (vla-put-lock (car item) (cdr (assoc "lock" (cdr item)))) (vl-catch-all-apply '(lambda () (vla-put-freeze (car item) (cdr (assoc "freeze" (cdr item))) ) ;_ end of vla-put-freeze ) ;_ end of lambda ) ;_ end of vl-catch-all-apply ) ;_ end of foreach ) ;_ end of defun (vl-load-com) (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))) ) ;_ end of vla-startundomark (if (and (not (vl-catch-all-error-p (setq selset (vl-catch-all-apply (function (lambda () (ssget '((0 . "INSERT"))) ) ;_ end of lambda ) ;_ end of function ) ;_ end of vl-catch-all-apply ) ;_ end of setq ) ;_ end of vl-catch-all-error-p ) ;_ end of not selset ) ;_ end of and (progn (vlax-for item (vla-get-layers adoc) (setq lst_layer (cons (list item (cons "lock" (vla-get-lock item)) (cons "freeze" (vla-get-freeze item)) ) ;_ end of list lst_layer ) ;_ end of cons ) ;_ end of setq (vla-put-lock item :vlax-false) (vl-catch-all-apply '(lambda () (vla-put-freeze item :vlax-false)) ) ;_ end of vl-catch-all-apply ) ;_ end of vlax-for (foreach blk_def (mapcar (function (lambda (x) (vla-item (vla-get-blocks adoc) x) ) ;_ end of lambda ) ;_ end of function ((lambda (/ res) (foreach item (mapcar (function (lambda (x) (vla-get-name (vlax-ename->vla-object x) ) ;_ end of vla-get-name ) ;_ end of lambda ) ;_ end of function ((lambda (/ tab item) (repeat (setq tab nil item (sslength selset) ) ;_ end setq (setq tab (cons (ssname selset (setq item (1- item)) ) ;_ end of ssname tab ) ;_ end of cons ) ;_ end of setq ) ;_ end of repeat tab ) ;_ end of lambda ) ) ;_ end of mapcar (if (not (member item res)) (setq res (cons item res)) ) ;_ end of if ) ;_ end of foreach (reverse res) ) ;_ end of lambda ) ) ;_ end of mapcar (vlax-for ent blk_def (vla-put-layer ent "0") (vla-put-color ent 0) (vla-put-lineweight ent aclnwtbyblock) (vla-put-linetype ent "byblock") ) ;_ end of vlax-for ) ;_ end of foreach (func_restore-layers) (vla-regen adoc acallviewports) ) ;_ end of progn ) ;_ end of if (vla-endundomark adoc) (princ) ) ;_ end of defun If that doesn't work you can run purge then at the top click onto "find Non-Purgeable Items" and in the details of the selected layer it should tell you if anything is still hiding on the layer you dont want and usually where to find it. hopefully this helps. 1 Quote
