Dear All,
I'm looking for a lisp that help dimension multiple points and polyline.I need to dimension as-built survey point and design.
9 hours ago, Kyaw said:
Dear All,
@Kyaw Please upload your sample.dwg with a before and an after
9 hours ago, devitg said:
@devitg,Here is my sample dwg.I need to dimension survey as-built point and design.It's take much time for columns and Core Wall.That's why I need help and I'm looking for a easier way to do this.
SAMPLE.dwg
@Kyaw As I can notice, all is at layer 0.
I guess that the original dwg have each entity at its own layer .
point
as build
as design.
Could you, please, arrange the layers to suit it?
Just for be clear when doing a selection set
  • Agree 1
My suggestion vlax-curve-getclosestpointto. Fairly simple in this case as points and a pline. Tricky bit is dim inside or outside, hor or ver.
