justkiddean Posted March 8, 2023 Posted March 8, 2023 Hello! I have a block/group with different linetypes in it (dashed, phantom, centerline, etc) with each linetype having different LTS; but for the sake of simplicity, each linetype have an LTS factor of 1. Is there a LISP to scale the block/group that will affect all the LTS factor in it? Like if i scale the block 5x, all of the LTS factor for each linetype will also automatically adjust to 5.00? Or I will have to change it manually in the properties? Thanks. Quote
BIGAL Posted March 8, 2023 Posted March 8, 2023 Possible answer is insert block then get scale. yes can go trhough the block entites and get the line and change its linetypescale either using VL or entmod. So hard part is how you determine which line to change in block. So post a sample dwg with block. Like this 2 lines bottom line changed. Quote
