BIGAL Posted March 8, 2023 Share Posted March 8, 2023 (edited) Steven P according to documentation "not filling up temp folder each time this runs" if you use VL MKtemp on closing Autocad the temp files will be deleted As a 2nd make sure I use (unload_dialog dcl_id) (vl-file-delete fname) Ok so if you bomb it out yes file can still exist, so from a cleaning up point of view I have my temp directory set to my D:\Acadtemp and run a bat file every now and then to delete file yes .dcl will be there. Have a look at your temp directory you may be horrified how much junk is in there. SV$, BAK, etransmit to mention a few. At my old work I cleaned mine had a look at some one elses PC had like 2GB of files. Edited March 8, 2023 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted March 9, 2023 Share Posted March 9, 2023 I'd agree with that BigAl - a part of this is being lazy when I am checking what is happening I know what temp file I am looking for (invariably things don't work right first time), and being lazy that I don't change it to go the other way. Stopped being horrified at the usual temp file contents years ago, mostly filled with junk left over from software updates Quote Link to comment Share on other sites More sharing options...
sln8458 Posted April 26, 2023 Author Share Posted April 26, 2023 Just a quick update. I managed to get this to work. For the action tile to close the main dialog and open the child i have: (action_tile "s1" ;toggle Fitting options "(L1_ON)(L1_CLEAR)(L5_OFF)(L5_CLEAR) (RESET_LABELS)(RESET_DIMS)(RESET_LIST) (SW_FIT_DIAG)" ); END ACTION TILE I have added a functio SW_FIT_DIAG: (defun SW_FIT_DIAG () ;SWITCH FITTINGS DIALOG (unload_dialog dcl_id_m) (NEST_FITTINGS) );end SW_FIT_DIAG For some reason having the unload statement and calling the new dialog (NEST_FITTINGS) in the S1 action tile statement didn't work!! Quote Link to comment Share on other sites More sharing options...
Steven P Posted April 26, 2023 Share Posted April 26, 2023 I'd be tempted to try nest fittings and then unload dialog see if that makes a difference - sometimes these things matter Quote Link to comment Share on other sites More sharing options...
sln8458 Posted April 26, 2023 Author Share Posted April 26, 2023 6 minutes ago, Steven P said: I'd be tempted to try nest fittings and then unload dialog see if that makes a difference - sometimes these things matter Hi Steve, I tried that, it was only when I created the seperate function that it worked. 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted April 26, 2023 Share Posted April 26, 2023 That's the beauty of LISP and DCL... sometimes works for no apparent reason! Quote Link to comment Share on other sites More sharing options...
