sivapathasunderam Posted March 1, 2023 Posted March 1, 2023 (edited) I was trying to make default cover page of 20 sections of a Project As I have attached a dwg There was 3 MTexts 1.) Text 1 - Section nos. it will varies but i need to fix it text height & positions to default 2.) Text 2 - Design status, previously all are preliminary design need to change to "Detailed Design" then text size then its positions x y to default 3.) Text 3 - All the previous dates needs to change to current month "MARCH 2023" then text size then it position x y to default I create a lisp that will select each text one by one, but help to fix the error ! (defun c:mycoverpage (/ ss ss1 ss2 e e1 e2 ) (if (setq ss (ssget "_:S" '((0 . "MTEXT")))) (Progn (setq e (ssname ss 0 )) (setpropertyvalue e "TextHeight" 15.00) (setpropertyvalue e "Position/X" -2959.684) (setpropertyvalue e "Position/Y" 730.225) (setpropertyvalue e "Position/Z" 0.00) ) ) (if (setq ss1 (ssget "_:S" '((0 . "MTEXT")))) (Progn (setq e1 (ssname ss1 0 )) (setpropertyvalue e1 "TextHeight" 14.00) (setpropertyvalue e1 "Position/X" -2957.874) (setpropertyvalue e1 "Position/Y" 689.120) (setpropertyvalue e1 "Position/Z" 0.00) (setpropertyvalue e1 "Contents" "\\pxqc;{\\C256;DETAILED DESIGN}") ) ) (if (setq ss2 (ssget "_:S" '((0 . "MTEXT")))) (Progn (setq e (ssname ss2 0 )) (setpropertyvalue e2 "TextHeight" 13.00) (setpropertyvalue e2 "Position/X" -2674.324) (setpropertyvalue e2 "Position/Y" 568.830) (setpropertyvalue e2 "Position/Z" 0.00) (setpropertyvalue e2 "Contents" "{\\fArial|b0|i0|c0|p34;\\C256;MARCH 2023}") ) ) (princ)) Cover Page default setting.dwg Edited March 1, 2023 by sivapathasunderam attached dwg Quote
Steven P Posted March 1, 2023 Posted March 1, 2023 I think this is your problem: "Position/X I'd be tempted to use entmod instead of setpropertyvalue - see the first text to change as an example, commented out your original lines (defun c:mycoverpage (/ ss ss1 ss2 e e1 e2 ) (if (setq ss (ssget "_:S" '((0 . "MTEXT")))) (Progn (setq ed (entget (ssname ss 0 )) ) (setq ed (subst (cons 40 15) (assoc 40 ed) ed )) (setq ed (subst (cons 10 (list -2959.684 730.225 0)) (assoc 10 ed) ed )) (entmod ed) ; (setq e (ssname ss 0 )) ; (setpropertyvalue e "TextHeight" 15.00) ; (setpropertyvalue e "Position/X" -2959.684) ; (setpropertyvalue e "Position/Y" 730.225) ; (setpropertyvalue e "Position/Z" 0.00) ) ) (if (setq ss1 (ssget "_:S" '((0 . "MTEXT")))) (Progn (setq e1 (ssname ss1 0 )) (setpropertyvalue e1 "TextHeight" 14.00) (setpropertyvalue e1 "Position/X" -2957.874) (setpropertyvalue e1 "Position/Y" 689.120) (setpropertyvalue e1 "Position/Z" 0.00) (setpropertyvalue e1 "Contents" "\\pxqc;{\\C256;DETAILED DESIGN}") ) ) (if (setq ss2 (ssget "_:S" '((0 . "MTEXT")))) (Progn (setq e (ssname ss2 0 )) (setpropertyvalue e2 "TextHeight" 13.00) (setpropertyvalue e2 "Position/X" -2674.324) (setpropertyvalue e2 "Position/Y" 568.830) (setpropertyvalue e2 "Position/Z" 0.00) (setpropertyvalue e2 "Contents" "{\\fArial|b0|i0|c0|p34;\\C256;MARCH 2023}") ) ) (princ)) 1 Quote
sivapathasunderam Posted March 1, 2023 Author Posted March 1, 2023 So why this is getting error? (setpropertyvalue e "Position/X" -2959.684) Quote
Steven P Posted March 1, 2023 Posted March 1, 2023 I'm not sure, someone else might know though Quote
devitg Posted March 1, 2023 Posted March 1, 2023 22 minutes ago, Steven P said: I'm not sure, someone else might know though I really do not know why. But you can use vla-put-insertionpoint (setq e1-obj (vlax-ename->vla-object e1)) (setpropertyvalue e1 "TextHeight" 14.00) (setq position-xyz ( list -2957.874 689.120 0.0)) ; new position (vla-put-InsertionPoint e1-obj (vlax-3d-point position-xyz)) 1 Quote
