kamo Posted March 1, 2023 Share Posted March 1, 2023 Hi everybody i want to know if there any method to project multiple polylines sides to another polyline like the image for example i want to lay the selected sides of this polylines to the inclined one thank a lot my friends Quote Link to comment Share on other sites More sharing options...
lrm Posted March 1, 2023 Share Posted March 1, 2023 (edited) Copy the 3 lines. Scale them by the ratio of the distances CD/AB Use align to position the scaled copies along the line passing through CD. Or use trim! Is there more to your question? Edited March 1, 2023 by lrm 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 1, 2023 Share Posted March 1, 2023 Are you wanting a manual out of box answer or a program to do it, do you know anything about Lisp in particular the VL function "Intersectwith". Quote Link to comment Share on other sites More sharing options...
kamo Posted March 2, 2023 Author Share Posted March 2, 2023 thanks all for the responding u help a lot thanks again Quote Link to comment Share on other sites More sharing options...
kamo Posted March 2, 2023 Author Share Posted March 2, 2023 On 3/1/2023 at 4:37 PM, lrm said: Copy the 3 lines. Scale them by the ratio of the distances CD/AB Use align to position the scaled copies along the line passing through CD. Or use trim! Is there more to your question? thanks bro align was the answer u r the best Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 5, 2023 Share Posted March 5, 2023 (edited) Do the vertical lines exist or are they there only to indicate the intersection points ? I ask as you can have just single lines and use the end points to make temporary lines that are vertical and as suggested "Intersectwith" does just that intersection of 2 objects. Edited March 5, 2023 by BIGAL Quote Link to comment Share on other sites More sharing options...
