help with text string...
hello all:
I am doing trying to modify a text string
I extract the dwgprefix variable and save it in a variable called "PATH1"
(setq PATH1 (getvar "dwgprefix"))
example:
"C:\Users\user1\Desktop\DWG\"
what i need is to modify this string
and that I get this as a result...
"C:\Users\user1\Desktop\PDF\"
that is, search the string "DWG" and replace it with "PDF"
and store it in a new variable called "PATH2"
taking into account that the chain can grow in length
but that the word "DWG" will always be found.
any comment is welcomed
thanks
I thought I had made it but no :(
Steven P
how I do this?
(tell the LISP you want to use the special character \)
Edited by leonucadomi
Use a double \\ instead of a single \
Try this both ways, once with singe \ and once with double \\
If you have a single \ in the string the last " will be seen as just text and not a closing " for example - and the LISP will fail. Put a space after the last \ and you'll see the difference better
(DEFUN c:tt ( / mystring )
  (setq mystring "C:\\Users\\user1\\Desktop\\DWG\\" )
  (princ (vl-string-subst "PDF" "DWG" mystring))
The file is in a folder called "DWG"
I want the string to change from "DWG" to "PDF"
try this but it keeps showing double bar  "\\"
and I want it to only generate a bar  "\"
to use that string as a path.
this is my code..
(defun c:test ( / prefix prefix2 path )
(setq prefix (getvar "dwgprefix"))
(setq prefix2 (vl-prin1-to-string prefix))
(setq path (vl-string-subst "PDF" "DWG" prefix2))
 (terpri)
 (princ path)
Why do I convert the dwg to pdf and send it to a folder called "pdf"
You are creating a text string with the new folder path, and I assume you are going to use that text string to do something else with it - which is what I was asking. After you have created the text string, what do you do with it?
(might be a couple of solutions to what you want but which to use depends what the text string is going to be for)
it's right
I need to generate the text string with the new route
Why do I print my dwg in pdf
then with this new path the generated pdf file will be saved in the correct location.
I use two folders
folder calls DWG
folder PDF
which are located in "x" folder
I can print my dwg in pdf and place it in the DWG folder
what I want to do is print it and send it to the other folder called PDF
that's why i need to manipulate the path i get with the variable DWGPREFIX
OK, in this case you should need to use a double '\\'
Try it and see perhaps with a test of the plotting routine you are making, at the plot stage type in the string in the LISP "C:\Users\user1\Desktop\PDF\" and see what it does....
If you type in the command line (getvar 'dwgprefix) it will show it with a double \\.... so in this case your code is OK at the moment, double \\s are good here.
  • Thanks 1
Use this.
; check that pdf directory exists
(setq dwgpre (strcat (getvar "dwgprefix") "\pdf"))
(if (= (vl-file-directory-p dwgpre) nil)
(vl-mkdir dwgpre)
  • Thanks 1
15 hours ago, BIGAL said:
Use this.
(vl-mkdir dwgpre)
FINDFILE works too:
(or (findfile (setq dwgpre (strcat (getvar "dwgprefix") "PDF"))) (vl-mkdir dwgpre))
  • Thanks 1
50 minutes ago, leonucadomi said:
thanks
Don't even really need to check:
(vl-mkdir (setq dwgpre (strcat (getvar "dwgprefix") "PDF")))
