Modify a BLOCK definition via lisp
Suha
Hello Guys,
Say, I have created a block with a single circle entity in it:
(entmake '((0 . "BLOCK") (2 . "myBlock")))
(entmake '((0 . "CIRCLE") (10 0 0 0) (40 . 5)))
(entmake '((0 . "ENDBLK")))
Now, I want to modify "myBlock" adding a line entity to this block definiton using pure AutoLisp. So that myBlock will contain a circle and a line at the end.
Any advice?
I googled before I write here BIGAL.
But the samples I met include vla functions however I am an intellicad guy and I seek a solution without vla's.
You can go right back to simplest but least efficient methods if you want
for example
(command "bedit" -blockname-)
  (entmake '((0 . "LINE") (10 0 0 0)(11 10 10 0) ))
(command "bsave")
(command "bclose")
Quicker than doing it manually.....
Though you could just make the line as a part of the block?
Thanks for the answer Steven P, but my question is to modify by adding /removing the entiti(es).
I came up with a solution like this:
(defun c:MakeBlock ()
	(entmake '((0 . "CIRCLE") (10 0 0 0) (40 . 5) (-3 ("AD_INSIDE" (1070 . 0)))))
(defun c:AddLineToBlock()
	(setq head (tblobjname "BLOCK" "myBlock"))
	(entmake (entget head))
	(setq circle (entnext head))
	(entmake (entget circle '("*")))
	(entmake '((0 . "LINE") (10 0 0 0) (11 15 15 0)))
	(command "_REGEN")
This achieves the solution I seek, but I expected to use (entmod (entget head)).
Is this the regular way or is there better way.
