MastroLube Posted February 23, 2023 Posted February 23, 2023 Hi there! I wrote a code that, from a selection, generates a polyline and a hatch for every object in the selection. How can I make these objects in the selection when the program is ended? For example: 1. I started my program 2. select the objects I want to evaluate 3. the program creates a polyline and a hatch for every object 4. done Now if I use the command COPY or MOVE (or whatever) I want to select these new objects with the key P (previous) and not the selection I made at point 2 above. Thanks for the help Dennis 2023-02-23-13-07-15.mp4 Quote
BIGAL Posted February 23, 2023 Posted February 23, 2023 When you make a new object you can use SSADD to add to say a second selection set so use that one for your move. Hint (ssadd (entlast) ss2) Quote
MastroLube Posted February 24, 2023 Author Posted February 24, 2023 Hello BIGAL! Unfortunately, I need something in c# I added the tag in the question, sorry for not making that more clear [CommandMethod("vs")] public void VerificaSovrapposizioni() { var TargetLayer = "DEST_LAYER"; #region Get the current document and database var doc = Application.DocumentManager.MdiActiveDocument; var ed = doc.Editor; var db = doc.Database; #endregion using (var tr = db.TransactionManager.StartTransaction()) { #region Open block table record model space var bt = (BlockTable) tr.GetObject(db.BlockTableId, OpenMode.ForRead); var btr = (BlockTableRecord) tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite); #endregion // create new layer called "_sovrapposizioni" var layerName = "_sovrapposizioni"; AddLayerIfNotExists(tr, db, layerName); // set the filter to select only polylines with the layer "_sovrapposizioni" var filter = new TypedValue[2]; filter[0] = new TypedValue(0, "LWPOLYLINE"); filter[1] = new TypedValue(8, TargetLayer); var sf = new SelectionFilter(filter); var res = ed.GetSelection(sf); if (res.Status == PromptStatus.OK) { var ss = res.Value; foreach (SelectedObject sObj in ss) if (sObj != null) { var ent = (Polyline) tr.GetObject(sObj.ObjectId, OpenMode.ForRead); var acObjIdColl = new ObjectIdCollection(); using (var acPoly = new Polyline()) { acPoly.ColorIndex = 2; acPoly.Layer = layerName; for (var i = 0; i <= ent.NumberOfVertices - 1; i++) acPoly.AddVertexAt(i, ent.GetPoint2dAt(i), 0, 0, 0); if (acPoly.NumberOfVertices < 4) { var pt1 = ent.GetPoint2dAt(0); var pt2 = ent.GetPoint2dAt(1); var angle = GetAngle(pt1, pt2); var distance = GetDistance(pt1, pt2); var pt3X = ent.GetPoint2dAt(2).X - distance * Math.Cos(angle); var pt3Y = ent.GetPoint2dAt(2).Y - distance * Math.Sin(angle); acPoly.AddVertexAt(3, new Point2d(pt3X, pt3Y), 0, 0, 0); } acPoly.Closed = true; btr.AppendEntity(acPoly); tr.AddNewlyCreatedDBObject(acPoly, true); acObjIdColl.Add(acPoly.ObjectId); } // Create the hatch object and append it to the block table record using (var acHatch = new Hatch()) { btr.AppendEntity(acHatch); tr.AddNewlyCreatedDBObject(acHatch, true); acHatch.SetHatchPattern(HatchPatternType.PreDefined, "SOLID"); acHatch.Layer = layerName; var color = Color.FromColorIndex(ColorMethod.ByAci, 1); acHatch.Color = color; // create a new transparency color for the hatch acHatch.Transparency = new Transparency(50); acHatch.Associative = true; acHatch.AppendLoop(HatchLoopTypes.Outermost, acObjIdColl); acHatch.EvaluateHatch(true); } } } tr.Commit(); } } Quote
BIGAL Posted February 25, 2023 Posted February 25, 2023 Same idea should work in c# must be an equivalent to ssadd as a C sub function. Quote
MastroLube Posted March 1, 2023 Author Posted March 1, 2023 I was able to add elements to the current selection, which is quite ok. (once you finish the program you find them already selected, without having to start a program and press P) Still not able to figure out how to replace previous objects with those just created ones. ... ObjectIdCollection IDs = new ObjectIdCollection(); ... IDs.Add(acPoly.ObjectId); ... IDs.Add(acHatch.ObjectId); ... ObjectId[] idArray = IDs.Cast<ObjectId>().ToArray(); ed.SetImpliedSelection(idArray); ... 2023-03-01-19-27-28.mp4 Quote
