BIGAL Posted February 20, 2023 Posted February 20, 2023 Hi anybody use OCR need to convert some paper documents to text just wondering what you used ? Understand accuracy of conversion. Quote
SLW210 Posted February 20, 2023 Posted February 20, 2023 Depends on what you have to work with. Last time I did this, a few decades ago, with great results was a page scanner with built in OCR, must be better these days. (probably cheaper as well) Adobe Acrobat Pro has an OCR, IIRC my old one did a pretty good job. There is FreeOCR, I haven't tried it, though. More recently, had a coworker do some online, but forgot the name, we tried several, most did okay. Another option is to use a scanning service if available. Quote
BIGAL Posted February 21, 2023 Author Posted February 21, 2023 Thanks will check out Acrobat pro. Quote
MastroLube Posted February 24, 2023 Posted February 24, 2023 (edited) If you need something for 1-page text and other screen text (images or tables for example) you can look at text grab. In alternative, powetToys has a lot of goodies for windows, which also included a powerful text extractor based on the above suggestion. Edit: Probably the online tool the other guy mentioned is contained here: https://www.online-convert.com/ Edited February 24, 2023 by MastroLube adding online converter option Quote
