Hi,
I am trying to copy a layer "DATE" from an old drawing file and then pasting to new drawing file. Following is the  VBA code...
Private Sub CommandButton1_Click()
    Dim oDoc As New AxDbDocument
    Dim nDoc As New AxDbDocument
    Dim newPath As String   'without layer and updated
    Dim oldPath As String   'to update
    UserForm1.Hide
    'Call the copyLayer()
    CopyLayers newPath, oldPath
End Sub
Private Sub UserForm_Activate()
    oldPath = "E:\ACE\Testing\09Dec\oldFile.dwg"
    newPath = "E:\ACE\Testing\30Jan\newFile.dwg"
    savPath = "E:\ACE\Testing\09Dec\oldFile_Copy.dwg"
End Sub
'To copy the Layers from newFile and pasting them to OldFile
Public Sub CopyLayers(ByVal newFile As String, ByVal oldFile As String)
    Dim oDbx As Object          'To update i.e OLD FILE
    Dim nDbx As Object          'Updated   i.e NEW FILE
    Dim olayer As AcadLayer
    Dim i As Integer
    With ThisDrawing.Application
        Set nDbx = .GetInterfaceObject("ObjectDBX.AxDbDocument.18")
    End With
    nDbx.Open FileName:=newFile
    'Copying the Layers from Updated File i.e NEW FILE
    Dim copyLay() As Object
    For Each olayer In nDbx.Layers
        If UCase(olayer.Name) = "DATE" Then
            ReDim Preserve copyLay(i)
            Set copyLay(i) = olayer
            'MsgBox olayer.Name
            i = i + 1
        End If
    Next
    'MsgBox i
    Dim idPairs As Variant
    'Dim copyObj As Variant
    'Opening the NEW FILE to copy the Layer
        Set oDbx = .GetInterfaceObject("ObjectDBX.AxDbDocument.18")
    End With
    oDbx.Open FileName:=oldFile
    nDbx.CopyObjects copyLay, ThisDrawing.Application.ActiveDocument.ModelSpace, idPairs
    oDbx.SaveAs savPath
    Set oDbx = Nothing
    Set nDbx = Nothing
End Sub
There no error, but my old file is not getting updated.. !! Whats wrong with this code???
Regards
JB
Just get a copy of Steal.lsp from www.Lee-mac.com does more than layers, can be command line driven so no user interaction, use (if (not steal)(load "StealV1-8)) to demand load the program a simple 1 line in your code.
  • Like 2
Expand
Dear BIGAL,
Thanks, first of all...
I will go through it, though, not much friendly with Lisp.
But what's the problem with my piece of code?
I have to do this for at least 50+ drawings, without manual intervention.
Regards
JB
Its not a problem to do to 50 dwgs. Use a script. I have done 100+ in one go.
I play around the edges of VBA, it may be like LISP once you go to the new dwg the VBA stops.
Have you inspected the variables to see what is inside them ?
Also look at scriptpro to write the script.
The lisp code
;;  The following example will attempt to import Layers: 'Layer1' & 'Layer2',
;;  C:\My Folder\MyDrawing.dwg' into the current drawing.                                       ;;
   (if (not Steal)(load "StealV1-8"))
  (Steal "C:\\My Folder\\MyDrawing.dwg"
              "Layers"
              ("Layer1" "Layer2")
(command "-save" "C:\\My Folder\\newMyDrawing.dwg")
(command "close")
The script
open dwg1
(load "mysteallayer")
open dwg2
opendwg3
Expand
Yes...
I have inspected the variables...
Till, opening the NEW document, everything is as expected by me...
But... "copyObjects()" is not working as expected...
Yes, I have worked with LISP, a decade ago. I will surely look into urs and Lee's code too.
Regards
JB
