Giovannino60 Posted February 16, 2023 Posted February 16, 2023 How do you proceed to insert an image in an autocad file and crop it with a circular shape? Thank you Quote
BIGAL Posted February 16, 2023 Posted February 16, 2023 Simplest way is attach in model space and then use a layout you can have a circle as a mview. Mview object. Quote
lrm Posted February 17, 2023 Posted February 17, 2023 Here's another way. Create a rectangle the size of the image and then use the polygon command to create an n sided polygon. I used 32 sides for this example. Explode both objects and delete one of the lines of the polygon. Create a polyline like the red one on the image below and the green line. Use PEDIT to join all the lines together to form a closed polyline. Use wipeout p n to create a wipeout. Move the noted red vertex so that is is coincident with the vertex in the top right corner. Place the wipeout shape over the image. It may be necessary to use draworder to move the image to the back. Change the color of the wipeout outline so that is blends with the background. Quote
ketxu Posted March 4, 2023 Posted March 4, 2023 Just use Rectangualar Viewport to show Image, then Draw a Circle show area you want, finally use VPCLIP command with Viewport and Circle Quote
Giovannino60 Posted March 4, 2023 Author Posted March 4, 2023 Explain to me what you mean by "rectangular window", can you give me a screenshot of the command to display the rectangular window? Thank you Quote
Cad64 Posted March 4, 2023 Posted March 4, 2023 On 3/4/2023 at 10:46 AM, Giovannino60 said: Explain to me what you mean by "rectangular window", can you give me a screenshot of the command to display the rectangular window? Thank you Expand I don't think anyone said "rectangular window". They said "rectangular viewport". If you're using Autocad 2010, your ribbon might appear different from my screenshot, but in 2018 you would go to the "Layout" tab and there you can create a rectangular viewport. Quote
Cad64 Posted March 4, 2023 Posted March 4, 2023 You can also use the VPORTS command to create a rectangular viewport. In the dialog box, select "Single" and then click "OK". Then click to select the first corner of the viewport, drag your cursor and click to select the 2nd corner. Quote
Cad64 Posted March 4, 2023 Posted March 4, 2023 Or you can use Bigal's suggestion and just create a circular viewport. 1. Draw a circle on screen. 2. Initiate the MVIEW command and then type "O" for "Object". 3. Select the circle to turn it into a viewport. Quote
Giovannino60 Posted March 5, 2023 Author Posted March 5, 2023 I figured out how to do it. It is sufficient to do so: 1) layout; 2) draw a circle 3) click on object. Quote
ketxu Posted March 6, 2023 Posted March 6, 2023 On 3/4/2023 at 10:46 AM, Giovannino60 said: Explain to me what you mean by "rectangular window", can you give me a screenshot of the command to display the rectangular window? Thank you Expand Oh, i mean Normal Rectangle Viewport ^^ Quote
