Stratos Posted February 15, 2023 Posted February 15, 2023 Hello to everyone! I wand to create a lisp file that prints on a loop while hiding and unhiding different layers. I am working on a cad software called 4MCAD. 4MCAD unfortunately does not have the native Autocad DWGtoPDF printer. The main problem I am facing is that I have to use third party printers to plot to PDF which ask for the name of the PDF file name on a seperate window. I have tried Nitro PDF creator, cutePDF, doPDF and I cannot figure out how to supress the pop-up window while giving the desired name to the PDF file. Has anyone know how to solve this problem? Can you get DWGtoPDF printer as system printer so my Cad software can find it? Has anyone suceeded with any third party software at giving the file name inside the lisp file? For example let's say that the desired filename is "C:\DWG_prints\DWGpr1.pdf" and I want a command like this: (command "-plot" "n" "" "" "" "n" "n" "" "C:\DWG_prints\DWGpr1.pdf" ) Quote
dan20047 Posted February 16, 2023 Posted February 16, 2023 Have you tried ghostscript as a printer? Haven't used in years but I recall it may print to file w/out dialog. https://www.ghostscript.com/releases/index.html See also this topic on theswamp https://www.theswamp.org/index.php?topic=50646.0 1 Quote
BIGAL Posted February 16, 2023 Posted February 16, 2023 This is default eg "dwg to Pdf" it is in windows what the printer name is or set the printer as default then printer hopefully is "Default Windows System Printer" This was a company printer name. (COMMAND "-PLOT" "Y" "" "\\\\PROD\\Lev5-04-BW" "A3" "m" "LANDSCAPE" "N" "W" "-6,-6" "807,560" "1=2" "C" "y" "Designlaser.ctb" "Y" "N" "N" "N" "N" "N" "y" ) ) Trying to remember how I got the name. Quote
Stratos Posted February 20, 2023 Author Posted February 20, 2023 Thank you dan20047, I used the Microsoft XPS printer which recognizes the paper sizes I already created for Nitro PDF creator. I only have to set up the Print settings for Nitro, apply to layout and then just change the printer in the command without changing any of the of the settings: Quote (vl-load-com) (if (not (vl-file-directory-p "C:\\DWG_prints\\PDFs\\")) (vl-mkdir "C:\\DWG_prints\\PDFs\\")) (setq DwgPfx "C:\\DWG_prints\\") (setq XPSFILE (strcat DwgPfx "Some Name with or without blanks")) (while (vl-string-search " " XPSFILE) (setq XPSFILE (vl-string-subst "_" " " XPSFILE)) ; Replace blanks with underscores in the filename ) (command "-plot" "n" "" "" "Microsoft XPS Document Writer" "y" XPSFILE "n" "y" ) ; Plot to XPS Expand After this I used the the topic on theswamp with the Ghostscript you suggested and the bat file which converts all the XPS Files inside the current folder. https://www.theswamp.org/index.php?topic=50646.0 I only added a command to change the current directory and a command to delete the XPS files after they have been converted: Quote @echo off setlocal enableDelayedExpansion cd "C:\DWG_prints" SET PROG=C:\DWG_prints\CONVERTER_DO_NOT_DELETE\gxpswin64.exe SET OPTS=-sDEVICE=pdfwrite -dNOPAUSE ::-sPDFSETTINGS=/prepress for %%F in (*.xps) do ( set "name=%%F" ren "!name!" "!name:*- Sheet - =!") :: create the PDFs for %%F in (*.xps) do ( echo Making PDF of: %%~nF.xps call %PROG% -sOutputFile="PDFs\%%~nF.pdf" %OPTS% "%%~nF.xps" DEL "%%~nF.xps") Expand Finally I call the bat file at the end of the lisp file with the following command: Quote (command "shell" "C:\\DWG_prints\\CONVERTER_DO_NOT_DELETE\\xpstopdf.bat") Expand 1 Quote
dan20047 Posted February 20, 2023 Posted February 20, 2023 Great to hear! Thanks for posting your solution. Real props go to JohnK at the swamp Quote
