Giovannino60 Posted February 14, 2023 Posted February 14, 2023 How do you cancel the inside of this writing, made with the screen? Thank you Stop.dwg Quote
Steven P Posted February 14, 2023 Posted February 14, 2023 Hatchedit and use 'add selected boundary' option selecting the part you want to remove Or recreate the hatch and select both lines, CAD will create the hatch from the outside line and create islands with anything inside that Quote
Giovannino60 Posted February 15, 2023 Author Posted February 15, 2023 I don't understand the buttons I have to click, to do the procedure, can you send me a screen shot? Thank you Quote
Steven P Posted February 15, 2023 Posted February 15, 2023 If you type the command 'hatchedit' into the command line, it will give you prompts to select the hatch to edit. There will then be a popup box, a button on the right side will be 'Add Selected Boundary' - click that and select the internal lines, hit enter, and follow the prompts. This is the autoDesk help for the command https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoCAD-Core/files/GUID-B2F5A812-81A8-48C2-83E1-C21708732CD5-htm.html Quote
Giovannino60 Posted February 15, 2023 Author Posted February 15, 2023 Do you mean this screen? In this case, what is the button I have to click, it's not clear from the translation? Thank you Quote
Steven P Posted February 15, 2023 Posted February 15, 2023 It is this one below, Command is hatchedit - you can use the English command by putting in a _ before the command ( _hatchedit ) and that should bring up the correct box - regardless of translations Select the hatch 'Add Selected Objects' - should be in the same place Quote
guran Posted February 15, 2023 Posted February 15, 2023 Try these settings: Command: HPISLANDDETECTION Enter new value for HPISLANDDETECTION <1>: Command: HPISLANDDETECTIONMODE Enter new value for HPISLANDDETECTIONMODE <1>: Quote
Giovannino60 Posted February 15, 2023 Author Posted February 15, 2023 I tried that command but it doesn't remove the center of the words, doesn't it change anything?. Quote
ColinPearson Posted February 20, 2023 Posted February 20, 2023 Click that little > arrow at the bottom right of the hatch dialog box. Check Island Detection and Normal. Then pick "ADD: Select Objects" under Boundaries and select all the geometry of each the letter(s) you want to Hatch. 1 Quote
