Bittuds1996 Posted February 11, 2023 Posted February 11, 2023 Dear Experts, I have tried the attached Code But when I run "Run-time error "-2145320851" show I Need your help on this subject Sub ExtractPolygonAreas() Dim acadApp As Object Dim acadDoc As Object Dim acadSelSet As Object Dim acadPoly As Object Set acadApp = GetObject(, "AutoCAD.Application") Set acadDoc = acadApp.ActiveDocument Set acadSelSet = acadDoc.SelectionSets.Add("polygons") acadSelSet.SelectOnScreen Dim i As Integer Dim j As Integer Dim area As Double Dim pointArray() As Double Dim xlApp As Object Dim xlWb As Object Dim xlWs As Object Set xlApp = CreateObject("Excel.Application") Set xlWb = xlApp.Workbooks.Add Set xlWs = xlWb.Sheets("Sheet1") xlWs.Cells(1, 1).Value = "Layer" xlWs.Cells(1, 2).Value = "Coordinates" xlWs.Cells(1, 3).Value = "Area" For i = 0 To acadSelSet.Count - 1 Set acadPoly = acadSelSet.Item(i) area = acadPoly.area pointArray = acadPoly.Coordinates xlWs.Cells(i + 2, 1).Value = acadPoly.Layer xlWs.Cells(i + 2, 2).Value = "(" For j = 0 To UBound(pointArray) - 1 Step 2 xlWs.Cells(i + 2, 2).Value = xlWs.Cells(i + 2, 2).Value & "(" & pointArray(j) & "," & pointArray(j + 1) & ")" Next j xlWs.Cells(i + 2, 2).Value = xlWs.Cells(i + 2, 2).Value & ")" xlWs.Cells(i + 2, 3).Value = area Next i xlApp.Visible = True xlWb.SaveAs "PolygonAreas.xlsx" End Sub Quote
PeterPan9720 Posted February 11, 2023 Posted February 11, 2023 Hi did you try to run procedure step by step with F8 function key ? just to understand with debugging the hang point. As second issue where are you devoloping the above procedure inside Autocad VBA or Excel VBA ? Quote
BIGAL Posted February 11, 2023 Posted February 11, 2023 Peterpan yes run from excel. Worked for me, are you trying to run in say Bricscad need a different "get application". Also need the co-ords to go down a row for each co-ordinate at moment all in 1 cell. Can do this from Acad, Bricscad etc open a new excel and fill in excel values. Its the same method but done in VL code. Quote
BIGAL Posted February 15, 2023 Posted February 15, 2023 Bricscad (vlax-get-or-create-object "BricsCadApp.AcadApplication") Quote
