  On 2/11/2023 at 3:32 PM, prodromosm said:
Hi  mhupp. Thanks for the reply, But I am not searching for a dynamic block because I don't use them. Look the *.dwg file.
Thanks
Expand
Please upload the test dwg , whit the 4 blocks  203 204  205 and 206 , inserted as you want they to be
  • 3 weeks later...
You have asked for lots of freebies you should know by now how to get an angle of 2 points or an included angle of 3 points then use a cond to select the correct block.
Edited by BIGAL
Hi Bigal. I can go so far
1) Pick the first point of the section
2) Pick the second point of the section
3) Pick a point for the direction of the section
4) Give the name for the section (A,B,A1, etc)
5) Draw the section line with marks like the example
(defun c:test ()
(setq pt1 (getpoint "\nSpecify first point: "))
(setq pt2 (getpoint p1 "\nSpecify second point:"))
(command "line" pt1 pt2 "")
;How to insert the blocks at the end of the line ??
(setq pt3 (getpoint "\nSpecify direction: "))
(setq ang1 (angle pt1 pt2))
);end defun
Thanks
Edited by prodromosm
