pegasus Posted February 9, 2023 Posted February 9, 2023 Hello, The dynamic blocks in the drawing I copied and pasted from an existing drawing to the Autocad LT page do not switch between the block objects I added, it's like frozen. I looked to see if it could be the version difference, but there is no problem with it either. Also, there is no problem when reopening the dynamic block that is causing trouble on a clean page, so there is no problem with the block. What is the reason and is there a short and practical solution for such situations? When you throw that dynamic block originating from the drawing into the drawing while it is working, the feature freezes. There's something blocking it in the drawing. Quote
pegasus Posted February 12, 2023 Author Posted February 12, 2023 here is. On 2/9/2023 at 11:15 AM, SLW210 said: Where's the drawing? dynamic error.dwgFetching info... Quote
