leonucadomi Posted February 8, 2023 Share Posted February 8, 2023 hello masters: I need to change the thickness to lines and polylines to zero value. How can I do it automatically when opening any file? help please. thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 8, 2023 Share Posted February 8, 2023 (edited) Thickness is a vertical height of a line or pline, used as a 2.5D to look like 3D.. Do you mean width or line weight. Edited February 8, 2023 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted February 8, 2023 Share Posted February 8, 2023 (edited) Chprop ALL (or select what you want to change) LW 0 -Edit can also be use to change thickness to 0 Edited February 8, 2023 by mhupp Quote Link to comment Share on other sites More sharing options...
Steven P Posted February 9, 2023 Share Posted February 9, 2023 and for lineweight or linewidth look at entmod the lines (there should be something online done to do that) and use codes 370 (for line weight) or 40 and 41 for line width (Polylines), all changed to 0 http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-C7D27797-247E-49B9-937C-0D8C58F4C832.htm,topicNumber=d30e612442 gives the basic Quote Link to comment Share on other sites More sharing options...
