ILoveMadoka Posted February 8, 2023 Share Posted February 8, 2023 (edited) After this discussion it was determined that a table style cannot be replaced in a simple step like you with blocks. Replace Table Style I was attempting to write a routine to rename three table styles so that I can bring in "new and improved" versions of those tables from a template. Given Tablestyles: Style1, Style2 & Style3 I'd like to rename to OLD1, OLD2 & OLD3 respectively... I do not know what I'm doing. This does not work at all. (defun C:RTS2 (/ oldname newname tbllist);;; (setq oldname "STYLE1" newname "OLD1") (setq tbllist (tblstyle)) (if (member oldname tbllist) (progn (command "tablestyle" oldname "rename" newname) (princ (strcat "Table style " oldname " renamed to " newname)) ) (princ (strcat "Table style " oldname " not found")) ) (princ) ) I found some code by Lee for deleting a Tablestyle but way over my head to modify to suit.. (defun c:deltab ( / dic sty ) ;;;Lee Mac (if (setq dic (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_TABLESTYLE")))) (progn (while (not (or (= "" (setq sty (getstring t "\nSpecify Table Style to Delete: "))) (dictsearch dic sty) ) ) (princ "\nTable Style not found.") ) (if (/= "" sty) (dictremove dic sty)) ) (princ "\nTable Styles not present in this version.") ) (princ) ) Lee says this is dangerous but may have some value for my use (defun c:deltab ( / dic ) (if (setq dic (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_TABLESTYLE")))) (foreach sty '("Style1" "Style2" "Style3") (dictremove dic sty) ;;I'm not wanting to delete them but rename them... ) (princ "\nTable Styles not present in this version.") ) (princ) ) Edited February 8, 2023 by ILoveMadoka Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted February 8, 2023 Author Share Posted February 8, 2023 Ok.. So I'm stupid... (command "_.rename" "T" "style1" "old1") I'd still like to see what a lisp routine using a different function would look like.. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted February 8, 2023 Share Posted February 8, 2023 6 hours ago, ILoveMadoka said: Ok.. So I'm stupid... (command "_.rename" "T" "style1" "old1") I'd still like to see what a lisp routine using a different function would look like.. (defun _rnt (old new / dic) ;; RJP » 2023-02-08 (and (setq dic (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_TABLESTYLE")))) (setq dic (dictsearch dic old)) (vl-catch-all-apply 'vla-put-name (list (vlax-ename->vla-object (cdr (assoc -1 dic))) new)) ) ) ;; usage (_rnt "Standard" "Testing123") Quote Link to comment Share on other sites More sharing options...
