  • barristann changed the title to Select previous
Can you describe what exactly you want?  Maybe we can help
5 hours ago, barristann said:
Anyone knows how long do I have to wait for my confirmation email from augi.com? It's been 24 hours. I'm trying to access this lisp
https://forums.augi.com/showthread.php?81175-select-result-lisp-modification&p=1310162&viewfull=1#post1310162
We could download it for you, but that wouldn't be proper is it. Be patient @barristann.
Let us know what you need and we will build the code for you from ground up, otherwise wait for the confirmation.
Cheers
I've ended up paying the fee. Thank you for your reply Emmanuel and pBe.
This is what I use. this gives me the option to select something or right click/enter to select the last thing modified. tho its kind of backwards with copied items it will select what you made a copy of rather then the copied items made.
;; Select or Previous
(defun SoP ()
  (prompt "\nSelect Objects or [Previous]:")
  (if (not (setq SS (ssget)))
    (setq SS (ssget "_P"))
-Edit
This is my move command using it.
;; Move Previous if nothing is slected.
(defun C:M (/ SS)
  (SoP)
  (if SS
    (vl-cmdf "._Move" SS "")
    (princ "\nNo previous selection set!")
Edited by mhupp
  • Like 3
Wonderful codes as always mhupp! Those are explanations are very helpful on how to get that working tombu. Thank you mhupp and tombu!
Nice mhupp. I will do the same with mine! Thank you again mhupp
