CyberAngel Posted February 3, 2023 Share Posted February 3, 2023 Every time I change to another layout or to model space, the command line shows two "*cancel*" messages. Does anyone know how to get rid of these messages? Quote Link to comment Share on other sites More sharing options...
mhupp Posted February 3, 2023 Share Posted February 3, 2023 Change the Layout Regen Options in AutoCAD. Go to Options > System tab > Layout Regen Options and select Cache model tab and all layouts Set the UPDATETHUMBNAIL (System Variable) to 0 (default is 15) to avoid capturing layout thumbnails when switching between layouts. Might be this might not (setvar LAYOUTREGENCTL 2) ;Runs regen 1 time only (setvar UPDATETHUMBNAIL 0) ;updates thumbnail when switching between layouts Also maybe "clean" the drawing by running purge and audit. 1 Quote Link to comment Share on other sites More sharing options...
