CyberAngel Posted February 3, 2023 Posted February 3, 2023 Every time I change to another layout or to model space, the command line shows two "*cancel*" messages. Does anyone know how to get rid of these messages? Quote
mhupp Posted February 3, 2023 Posted February 3, 2023 Change the Layout Regen Options in AutoCAD. Go to Options > System tab > Layout Regen Options and select Cache model tab and all layouts Set the UPDATETHUMBNAIL (System Variable) to 0 (default is 15) to avoid capturing layout thumbnails when switching between layouts. Might be this might not (setvar LAYOUTREGENCTL 2) ;Runs regen 1 time only (setvar UPDATETHUMBNAIL 0) ;updates thumbnail when switching between layouts Also maybe "clean" the drawing by running purge and audit. 1 Quote
