devitg Posted January 30, 2023 Share Posted January 30, 2023 (edited) As I try to load geomcal I got this error On acad 2019 , w10 (if (findfile "geomcal.crx") (arxload "geomcal") ) ; error: ARXLOAD failed Also if I try from command line Command: (load "geomcal") ; error: LOAD failed: "geomcal" ; reset after error What could be wrong. Thanks in advance Edited January 30, 2023 by devitg correct spelling Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 30, 2023 Share Posted January 30, 2023 This came up earlier!! The answer suggested just (arxload "geomcal") So maybe try without the findfile? There is also a vl- version ( maybe (vl-arx-import "geomcal.arx") which the example has an 'arx' suffix and not your 'crx' ? 1 Quote Link to comment Share on other sites More sharing options...
