Help-move text or mtext to midpoint of 2 points, then move 1 unit above
Hi all. Is it possible to modify this ronjonp & Alan H code to also move the Text or Mtext 1 unit above (the imaginary line created by these 2 points)? Thank you.
https://www.cadtutor.net/forum/topic/65000-lisp-routine-to-move-text-or-mtext-to-midpoint-of-2-points/
;; Ronjonp - 03.22.2018 mid pt of two pts
(defun _mid (p1 p2) (polar p1 (angle p1 p2) (/ (distance p1 p2) 2.)))
; modified by Alan H basicly supports any object that can have a bounding box 03.23.2018
(defun c:foo (/ e p p1 p2)
(setq e (vlax-ename->vla-object (car (entsel "pick object"))))
(vla-getboundingbox e 'll 'ur)
(setq p (mapcar 'vlax-safearray->list (list ll ur)))
(setq p1 (getpoint "pick 1st point"))
(setq p2 (getpoint "pick 2nd point"))
(vlax-invoke e 'move (_mid (car p) (cadr p)) (_mid p1 p2))
(vl-load-com)
(c:foo)
Edited by barristann
  • barristann changed the title to Help-move text or mtext to midpoint of 2 points, then move 1 unit above
I changed it a bit.
I use (vla-move instead of (vlax-invoke e 'move
I hope you don't mind.
I'm not sure which you want,
foo puts the point 1 unit up vertically
foo2 puts the point 1 unit offset to the imaginary line p1-p2
I think you want foo2.  Anyway, here's both.
change the bottom line if needed to
(c:foo2)
;; raise a point by a certain amount, vertically
(defun raise (p1 by / )
	(list
		(nth 0 p1)
		(+ (nth 1 p1) by)
(defun offset_by (p1 ang by / )
	(polar p1 (+ ang (/ pi 2.0)) by)  ;; angle of p1-p2 + 90°
(defun c:foo (/ e e_ p p1 p2 p3)
	(setq p3(_mid p1 p2) )
	;; raise it by 1 unit
	(setq p3 (raise p3 1.0))
	(vla-move e (vlax-3d-point (_mid (car p) (cadr p))) (vlax-3d-point p3))
(defun c:foo2 (/ e e_ p p1 p2 p3)
	;; offset it by 1 unit
	(setq p3 (offset_by p3 (angle p1 p2) 1.0))
(vl-load-com)
(c:foo)
Edited by Emmanuel Delay
  • Like 3
I was so busy at work so sorry for the late reply. I thought it could not be done. But wow, you've nailed it, Emmanuel! It's exactly what I was hoping for. Thank you Emmanuel!
On 1/30/2023 at 7:17 AM, Emmanuel Delay said:
I changed it a bit.
(c:foo2)
	(list
		(nth 0 p1)
		(+ (nth 1 p1) by)
(vl-load-com)
(c:foo)
Hi Emmanuel, why  do you prefer?
Thanks in advance
