Lisp to detect clashes between polylines and circles
Hello everyone,
i am asking if there is a lisp that could detect any clashes between blue polylines and magenta polylines and circles. If there is a clash blue polylines can change color to yellow for example just to be highlighted. You can fined the following screenshots as a reference and also dwg file attached.
Thanks in advancenew block.dwg
Are blue LINE(s) or POLYLINE(s)?
If LINE(s), it's simple, but if not, then also account that magenta rectangles would change to yellow...
the blue are actually polylines, anyway if the magenta would change to yellow no problem, but the magenta rectangles or circles should change to yellow
(defun c:foo ( / ss i el e1x e2x )
  (vl-load-com)
  (if (setq ss (ssget "_A" (list (cons 0 "*POLYLINE,CIRCLE"))))
      (setq el (cons (ssname ss (setq i (1- i))) el))
  (foreach e1 el
    (setq el (vl-remove e1 el))
    (foreach e2 el
      (if (vlax-invoke (vlax-ename->vla-object e1) (quote intersectwith) (vlax-ename->vla-object e2) acextendnone)
          (entupd (cdr (assoc -1 (entmod (subst (cons 2 62) (assoc 62 (setq e1x (entget e1))) e1x)))))
          (entupd (cdr (assoc -1 (entmod (subst (cons 2 62) (assoc 62 (setq e2x (entget e2))) e2x)))))
Untested, though, but should work...
HTH.
M.R.
  (vl-load-com)
  (foreach e1 el
    (foreach e2 el
HTH.
M.R.
Thank you for your work, but i tried it and it does nothing at all
Maybe objects don't touch, for ex. - different elevations, but from TOP view they clash...
i made flatten to all objects, still nothing happens
I have no further conclusions... I strongly believe that the code is good, but in your comments I see that it's not what's expected...
So long from me...
M.R.
So long from me...
M.R.
No worries, thanks for your help
An alternative is to use (ssget "F" points where the points are the polyline points it will find any object that touches say the blue pline, only gotcha is must check for the blue pline in the selection set returned and disregard. Will try to find something.
