Help with lisp: Math calculation in TEXT or Mtext
Hi, I am using this code to do calculation in text or mtext
for example, I have a text
6.00*8.00*2.70 + 6.00*8.00*(3.90-2.70)*1/3 + 1.70*3.00*2.38
and convert the text to the result
160.94
The problem is sometimes gives this error and I don't know why?
; error: no function definition: CAL
Here is the code I use
(defun c:cal2 (/ e)
  (setq e (car (entsel "\Select text or mtext: ")))
  (setq e (vlax-ename->vla-object e))
  (vlax-property-available-p e 'textstring)
  (vla-put-textstring e (atof (rtos(cal (vla-get-textstring e)) 2 2)))
Thanks
Edited by prodromosm
If I run cal (autocad calculator) and do one simple calculation for example  3+2=5 then the lisp work without error. I don't kanow why this  code stop work. In the begining befor 2 years this code works fine. Any options?
Thanks
Thanks Tsuky. I add this line and I think is working. I will test it more. Thanks
(defun c:cal2 (/ e)
  (arxload "geomcal")
Copy and paste does not work most of the time without understanding the procedure of codes at least, so here is the missing part of your codes.
(c:cal (vla-get-textstring e)) ;; note the c: before the cal command name
It works both ways for me, with a 'c:' and without it, AutoDesk help shows it both ways.
Edited by Steven P
  • Thanks 1
So this routine is fixed in this instance but it doesn't explain why it worked sometimes and not sometimes.
I might take a guess that you use some other calculations and if you haven't used one before in that session then 'geomcal' isn't loaded yet.
"; error: no function definition: CAL" tells us that the function 'CAL' hasn't been loaded into memory for that drawing.. if you get a similar error in the future it means even if you have it saved in a file somewhere it still needs loading for the LISP to use it.
Hi Steven P. I explain that cal command is Autocad cal command. I have no extra cal command to load. When i add this line
(arxload "geomcal")
The problem solved. I will add and Tharwat suggestion
(vla-put-textstring e (atof (rtos(c:cal (vla-get-textstring e)) 2 2)))
Thanks
(arxload "geomcal")
.... OK.... so don't load the command with arxload....
