Hi,
I want to explode the text and mtexts written in a certain layer and make a line. The txtexp command both has to make a selection and pulls it to the current layer. Is there any solution about this? Thank you from now.
You also might want to join the lines after the explostion. if your going use the new geometry somehow.
7 minutes ago, BIGAL said:
Post a image or better yet a dwg.
here is an mtext. With the autocad txtexp command, this text takes the properties of whatever layer exists at that moment. I also wrote the texts I want to line in a single layer and I want to select the text, text in that layer.
0.dwg
;; EXPLODES TEXT AND MOVES TO CURRENT LAYER
(defun C:FOO (/ SS SS1 LastEnt lay)
  (vl-load-com)
  (setq ss1 (ssadd))
  (if (setq SS (ssget))
      (setq LastEnt (entlast))
      (command "_.Txtexp" SS "")
      (while (setq LastEnt (entnext LastEnt))
        (ssadd LastEnt SS1)
  (if (> (sslength SS1) 0)
      (command "_.CHPROP" SS1 "" "_LA" (getvar 'clayer) "")
Edited by mhupp
  (vl-load-com)
  (setq ss1 (ssadd))
      (vl-cmdf "_.Txtexp" SS "")
        (ssadd LastEnt SS1)
sorry, didn't work
but there is TXTEXP command in Autocad. how does it not detect
Select objects:
_.Txtexp Unknown command "TXTEXP".  Press F1 for help.
Command: <Selection set: 639>
Changed out vl-cmdf to command that might help.
Edited by mhupp
I do not why , fom lisp I get this
But from command line TXTEXP. work as expected
neither with
Edited by devitg
add vl-cmdf
neither with
I get the same result with add vl-cmdf . what could be the reason
You updated to?
20 hours ago, mhupp said:
You updated to?
EXPLODES TEXT AND MOVES TO OWN LAYER
Best answer is download "Text 2 geom by Seant", he lingers here at times. He should advise you of correct download link. This will do True Type Fonts as well.
maybe when the text and mtexts are lines, I should be in that layer with the command and all the selected text,mtexts in the layer I specified should return to the line. But of course it throws an error. where did i go astray?
(defun c:fin ( / ss i e)
(setq (ssget 'CLayer (layerName "LAYER1")))
(and
(if (setq ss (ssget "_X" '((0 . "TEXT,MTEXT"))))
(and (wcmatch (vla-get-objectname mdl) "AcDbMText,AcDbText")
              (wcmatch (strcase (vla-get-layer mdl)) "LAYER1"))
    (setq e (ssname ss (setq i (1- i))))
       (command-s "_.Zoom" "Object" e "")
    (sssetfirst nil (ssadd e))(C:TXTEXP)
1 hour ago, tombu said:
Honestly have no idea what you're trying to do but the quickest and easiest way to create a linetype with text is using ronjonp's "Make Linetype With Embedded Characters": https://www.theswamp.org/index.php?topic=47058.msg520876#msg520876
no actually it is not. I want text and mtexts written in a certain layer to make the selection txtexp. The lines formed should carry the properties of the previous layer, not the current one.
Try with this
(defun c:my_txtexp ( / ss n ent dxf_ent lay sel lastent next lastent e dxf_e)
  (setq ss (ssget ":L" '((0 . "*TEXT"))))
  (cond
    (ss
      (if (not c:txtexp) (load "txtexp"))
      (repeat (setq n (sslength ss))
        (ssadd)
        (setq
          ent (ssname ss (setq n (1- n)))
          dxf_ent (entget ent)
          lay (cdr (assoc 8 dxf_ent))
          sel (ssadd ent)
          lastent (entlast)
        (sssetfirst nil sel)
        (c:txtexp)
        (if (and lastent (entget lastent))
            (setq
              sel nil
              sel (ssadd)
            (while
              (setq next (entnext lastent))
              (ssadd next sel)
              (setq lastent next)
              sel
        (if sel
          (repeat (setq i (sslength sel))
            (setq
              e (ssname sel (setq i (1- i)))
              dxf_e (entget e)
              dxf_e (subst (cons 8 lay) (assoc 8 dxf_e) dxf_e)
              dxf_e (subst (cons 62 256) (assoc 62 dxf_e) dxf_e)
            (entmod dxf_e)
  (prin1)
really thank you for your help @Tsuky. Even in this state, it is very useful to select the text and mtexts in the layer I want with select similar and run this command.
16 hours ago, Tsuky said:
Try with this
  (cond
    (ss
        (ssadd)
        (setq
          sel (ssadd ent)
          lastent (entlast)
        (c:txtexp)
            (setq
              sel nil
              sel (ssadd)
            (while
              (ssadd next sel)
              (setq lastent next)
              sel
        (if sel
            (setq
              dxf_e (entget e)
            (entmod dxf_e)
  (prin1)
  • 1 year later...
On 2/5/2023 at 10:40 PM, BIGAL said:
tombu trying to find latest version. I have something.
How to use this ,
I selected the text and run the command but it shows this.
Edited by thetechgeekko
