rcb007 Posted January 26, 2023 Posted January 26, 2023 I am trying to understand how to write this routine instead of creating several small basic routines. For an example, I want to be able to ask the user what scale would you like, then it would adjust the cannoscale variable and then the zoom scale variable. Currently, I use a lot of DCLs with Buttons that the users select what scale they want and then it would run that specific routine for that scale. (defun C:Demo_Set_Scale_Annotation () (command "_layout" "set" "") (comamnd "mspace") (command "_.cannoscale" "1\" = 50'") (command "_.zoom" "scale" "1/50xp") (command "pspace") (command "_.zoom" "extents") (princ) ) Thank you for any help and advise. Quote
BIGAL Posted January 26, 2023 Posted January 26, 2023 (edited) A couple of simple changes. (setq val (getint "\nNew scale - Enter = 50 ")) (if (= val nil) (setq val 50)) (command "_.cannoscale" (strcat "1\" =" (rtos val 2 0) "'")) (command "_.zoom" "scale" (strcat "1/" (rtos val 2 0) "xp")) version 2 this will pop a dcl without you doing any code. (if (not AH:Butts)(load "Multi Radio buttons.lsp")) (setq ans (atoi (ah:butts 3 "V" '("Choose a scale" "10" "20" "50" "100" "200" "250" "500" )))) ; ans holds the button picked as an integer value Multi radio buttons.lsp Edited January 26, 2023 by BIGAL 2 Quote
mhupp Posted January 27, 2023 Posted January 27, 2023 (edited) Have to multiply val by 12 to get the correct scale factor of 1/600xp = 1:50' (command "_.zoom" "scale" (strcat "1/" (rtos (* val 12.0) 2 0) "xp")) Edited January 27, 2023 by mhupp Quote
rcb007 Posted January 27, 2023 Author Posted January 27, 2023 Thank you for the help. I can see the relationship by using the variable rather than the other way around. Quote
