QuinnL Posted January 25, 2023 Posted January 25, 2023 Still learning Autolisp, so sorry if it is any easy solution I overlooked. For approval, our city requires we send them our CAD files (civil 3d). With the new 2023 manual, we need to change our layers names to match the ones they gave us. Below is the code I currently have which uses the command "rename". It seems to mostly work however, I have two problems. 1. If the layer does not existing in the dwg, the command gives me "; error, function cancelled'. (Maybe an if statement that says to only run the command if the layer can be found in the dwg??) 2. The command "rename" seems to also not like it when the layer name you are switching to already existing in the dwg. I believe that gives me an error too. Thanks for the help. Quote
Steven P Posted January 25, 2023 Posted January 25, 2023 (edited) The option from Lee Mac here is a good start Make a list of the layers and loop through this Edited January 25, 2023 by Steven P 2 Quote
BIGAL Posted January 25, 2023 Posted January 25, 2023 (edited) Layer rename supports wildcards so may be able to do a "sl-*" "xx-*" You can check if a "sl-*" layer exists using (setq ss "X" '((8 . "sl-*"))) if ss is not nil proceed. You can check if layer exists by (tblsearch "LAYER" "sl-pl") I would set up a file with all the layer names as a CSV file then read it you can make it in excel and save as csv. This way can do 100's "sl-pl,xx-lots-ln" So I have not posted anything as are you happy with file idea ? Did the same task but we just added EX- to certain layers to identify existing features. Ex-lip v's Lip Edited January 25, 2023 by BIGAL 1 Quote
ronjonp Posted January 25, 2023 Posted January 25, 2023 Look into the LAYTRANS command too. If you want to stick with the lisp it could be refactored like so to check if the source layer exists. (foreach layer '(("SL-PL" "XX-LOTS-LN") ("SL-BNDRY" "XX-SUB-BDY")) (if (tblsearch "LAYER" (car layer)) (command "_.RENAME" "_LAYER" (car layer) (cadr layer)) ) ) 2 Quote
Sharper Posted January 27, 2023 Posted January 27, 2023 Quick question please.... I see BIGAL says rename supports wildcards Does tblsearch also support wildcards? Quote
mhupp Posted January 27, 2023 Posted January 27, 2023 Not In BricsCAD, but try it out in AutoCAD. : (tblsearch "layer" "Te*") nil : (tblsearch "layer" "Test") ((0 . "LAYER") (2 . "Test") (70 . 0) (62 . 2) (6 . "Continuous")) 1 Quote
mhupp Posted January 27, 2023 Posted January 27, 2023 Here are my three functions for layers. Rename, Merge and create ;;----------------------------------------------------------------------------;; ;; Rename Layers (RLayer '(oldlayers1, oldlayers2) '(newlayer1, newlayer2)) (defun RLayer (#OldLayers #NewLayers / #Layers) (vl-load-com) (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (mapcar '(lambda (o n) (and (tblsearch "layer" o) (not (tblsearch "layer" n)) (vl-cmdf "_-Rename" "LA" o n) ) ;_ and ) ;_ lambda #OldLayers #NewLayers ) ;_ mapcar ) ;;----------------------------------------------------------------------------;; ;; Merge Layers (MLayer '(oldlayers1, oldlayers2) '(newlayer1, newlayer2)) (defun MLayer (#OldLayers #NewLayers / #Layers) (vl-load-com) (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (mapcar '(lambda (o n) (and (tblsearch "Layer" o) (or (tblsearch "layer" n) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (cons 2 n) '(70 . 0) '(62 . 3)))) (progn ;;BricsCAD has a merge layer but its not a typed command autocad code could clean up this one funtion (setq SS (ssget "X" (list (cons 8 o)))) (vl-cmdf "_Chprop" SS "" "LA" n "") (vl-cmdf "_Purge" "LA" o "N") ) ) ;_ and ) ;_ lambda #OldLayers #NewLayers ) ;_ mapcar ) ;;----------------------------------------------------------------------------;; ;; Create New Layers (NLayer '(newlayer1, newlayer2 ....)) (defun NLayer (#NewLayers / lay) (foreach lay #NewLayers (if (not (tblsearch "Layer" lay)) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (cons 2 lay) '(70 . 0) '(62 . 3))) ) ) ) So I would have something like this (defun C:updatelayers () (RLayer '("lay1" "lay2" "lay3") '("Newlay1" "Newlay2" "Newlay3")) ;Rename old layer first if new layer isn't existing (MLayer '("lay1" "lay2" "lay3") '("Newlay1" "Newlay2" "Newlay3")) ;merge old layer to new layer if both layers exist (Nlayer '("Newlay1" "Newlay2" "Newlay3")) ;create new layer if not existing already ) Quote
Sharper Posted January 27, 2023 Posted January 27, 2023 No, doesn't work in AutoCAD Shame that. Could be a game changer. Thanks for the speedy reply Quote
Steven P Posted January 27, 2023 Posted January 27, 2023 (edited) Just quickly searches through table listing and returns all that is found... if you put a * in the search term as a wild card too.... (defun c:testthis( / MyLayersList acount result ) (defun Table (s / d r) (while (setq d (tblnext s (null d))) (setq r (cons (cdr (assoc 2 d)) r)) ) ) (setq result (list)) ; make a blank list (setq MyLayersList (Table "layer") ) ; get list of all layers (setq Mystring (getstring "\nEnter Seach term" T)) (setq acount 0) (while ( < acount (length MyLayersList)) (if (= (wcmatch (nth acount MyLayersList) Mystring) nil) (princ "\n not Matched") (setq result (append result (list (nth acount MyLayersList)) )) ) ; end if (setq acount (+ acount 1)) ) ; end while result ) Might need to do a loop from the result to rename the layers? ... and because dinner is still cooking, the same thing with a foreach loop (slightly shorter code) (defun c:testthis( / MyLayersList result ) (defun Table (s / d r) (while (setq d (tblnext s (null d))) (setq r (cons (cdr (assoc 2 d)) r)) ) ) (setq result (list)) ; make a blank list (setq MyLayersList (Table "layer") ) ; get list of all layers (setq Mystring (getstring "\nEnter Seach term" T)) (foreach x MyLayersList (if (= (wcmatch x Mystring) nil) (princ "\n not Matched") (setq result (append result (list x) )) ) ; end if ) ; for each result ) Edited January 27, 2023 by Steven P 2 Quote
Sharper Posted January 27, 2023 Posted January 27, 2023 I like this StephenP... I've had a similar issue but slightly different with layer naming issues, this will help a lot. Also... Just to make sure i'm reading this code correctly (still new to this coding game) Am I right, that this could be modified to search the "Blocks" table? , and, if i entered Chamfer* (for example) into the search term i could then, after another tweak, using the foreach, have it insert all blocks starting with chamfer (eg chamfer1204, chamfer 2306 etc) 1 Quote
Steven P Posted January 27, 2023 Posted January 27, 2023 (edited) Try it and see... (seriously... it is the best way to learn! and is all I would be doing anyway) Edited January 27, 2023 by Steven P 1 1 Quote
Sharper Posted January 27, 2023 Posted January 27, 2023 (edited) Yeah, I will do, i'm just finishing up for the evening but i'll try to adapt it over the weekend edit: I got this to work for my needs Changed (setq MyLayersList (Table "layer") ) ; get list of all layers To setq MyBlocksList (Table "Block") ) ; get list of all Blocks And (setq Mystring (getstring "\nEnter Seach term" T)) To (setq Mystring "Chamfer*") ; at tthe moment, this is all i need, so rather than keep typing it in.. And then adding (foreach x result (COMMAND ".-INSERT" x "E" "Y" "S" "1" "R" "0" "0,0") ) I agree, it is the best way to learn. I'm getting comfortable now being able to edit to suit my needs. I do however struggle to think of the best approach when creating my own from scratch. They tend to start off very large and cumbersome, and as I learn or see how someone else has tackled a similar issue, I go back and make them more efficient. Thanks again guys for the help (sorry Quinnl, for joining in on this, i hope you get what you need... these guys are awesome) Edited January 30, 2023 by Sharper Added results of a weekends coding 1 Quote
BIGAL Posted January 27, 2023 Posted January 27, 2023 (edited) My $0.05, you will need to change where the csv file is located and its name, note the dbl \\ in file name. You can use GETFILE if you want to pick the file. ; thanks to Lee-mac for this defun ; 44 is comma 32 is space (defun csv->lst ( str / pos ) (if (setq pos (vl-string-position 44 str)) (cons (substr str 1 pos) (csv->lst (substr str (+ pos 2)))) (list str) ) ) (defun c:wow ( / fo nline nstr oldlay newlay) (setq fo (open (setq fname "D:\\acadtemp\\quinn-layer.csv") "R")) (while (setq NLINE (read-line fo)) (setq nstr (csv->lst nline)) (setq oldlay (car nstr) newlay (cadr nstr)) (if (tblsearch "layer" oldlay) (command "rename" "layer" oldlay newlay) (princ "\nNo layer") ) ) (close fo) (princ) ) (c:wow) CSV file sl-pl,xx-lots-ln sl-bndy,xx-sub-bdy sl-esmt,xx-esmt sc-bldg,xx-building-ftprnt Ps not tested as need a test dwg. Edited January 27, 2023 by BIGAL Quote
